pooleside opened this issue on Jul 02, 2000 ยท 5 posts
pooleside posted Sun, 02 July 2000 at 4:03 PM
Is there any way to have the background of the project window in RDS 5.5 be a frame of video so that I can animate objects that sync up with my quicktime video clips. I'd like to animate a poser figure etc walking past a videotaped actor etc? Poser allows such a simple function, but I can't find a good way to do similar with studio 5.5. Any help is great! Thanks Steve
willf posted Sun, 02 July 2000 at 5:58 PM
There are two ways to do this: You can add a movie to the backround in the "Current Scene Settings > Effects" dialog box or you can create a box and map a movie to the surface in the Shader Editor > Insert Movie. Great way to build a TV set or movie screen.
AzChip posted Mon, 03 July 2000 at 10:17 AM
Steve - Bear in mind that if you're working in Windows, you can't import Quicktimes into RDS; it can only handle AVI's or sequenced images. (The reverse is true, too; Mac's can't handle AVI's. Kinda frustrating, actually....) I'm sure there must be some conversion utility out there (I use AfterEffects -- a little pricey, but I already have it....). - Chip
willf posted Mon, 03 July 2000 at 11:15 AM
Quicktime Pro for WIN ($30.00) will also convert to AVI & several other formats. Quicktime Movieplayer 2.5 (MAC) will also do the conversions if you have the full install of the latest QT with all the extensions.
brenthomer posted Tue, 04 July 2000 at 11:27 PM
Speaking of quicktime..did anyone else but me feel ripped off when you read on the carrara site that you can export quicktime movies and then find out that you had to actually go buy quicktime seperately? I work with a lot of video software and I have never installed it and found out I needed to give quicktime more money....grrrr
