Doublecrash opened this issue on Jul 21, 2003 ยท 13 posts
Doublecrash posted Mon, 21 July 2003 at 5:03 AM
Doublecrash posted Mon, 21 July 2003 at 5:05 AM
Ah, yes. I had atmosphere off because it played too heavy with the lights, that's why I hadn't any haze in the pic (sorry, it seems I can't find the original bryce render). Working with atmosphere off is way faster, and the grayscale solved the problem. S.
Slakker posted Mon, 21 July 2003 at 8:26 AM
Man...i've been all like "Gah, i can't get the right look" or something like..."Man, this looks like crap." Maybe this will fix it. Did you do this with textures off, or is this default distance mask? (never done a distance mask render.)
Doublecrash posted Mon, 21 July 2003 at 9:05 AM
Default distance mask. And it's incredibly fast, too. At 1280x1024 took no more than a couple of minutes.
Rayraz posted Mon, 21 July 2003 at 9:56 AM
Bryce adapts the grey-values to the size of the scene, so the size of your objects shouldn't affect the usability of this feature. I used distance renders on some of my images for haze or some other effects. It's just about as fast as maskrenders, but it's still possible to slow it down. I made a tunnel with 15.800 primitives and it took more then 2 hours to make a distance render at 675x900.
(_/)
Hepcatbrandon posted Mon, 21 July 2003 at 2:36 PM
you can also use this to create a nice and quick DOF effect
Doublecrash posted Mon, 21 July 2003 at 5:06 PM
Whoa, RR, 15800?... it's the tunnel in the bground of your last posting? @Hepcat: yes, I made it because I wanted to use it for DOF, but then put aside the idea and instead used it only for hazing a bit the picture.
Hepcatbrandon posted Mon, 21 July 2003 at 6:23 PM
ahhhh, I missed that. Nice image by-the-way
Incarnadine posted Mon, 21 July 2003 at 9:09 PM
A novel idea, will have to try this in future. Thanks for the pointer!
Pass no temptation lightly by, for one never knows when it may pass again!
Rayraz posted Tue, 22 July 2003 at 6:08 AM
The DOF thing is actually in the manual :) @DC; Yes, that the tunnel I used for the background of my last posting.
(_/)
catlin_mc posted Tue, 22 July 2003 at 8:01 AM
I've only used distance mask once and I now forget what I did with it, but since you've brought it to my attention I think I'll go play with it again. 8) Catlin
danamo posted Tue, 22 July 2003 at 2:23 PM
Great technique Stefano, thanks!
Rayraz posted Tue, 22 July 2003 at 3:07 PM
You can use it to blend the varying color of sky's with the scene too. A bit like a multicolor haze. Just delete all the objects from your scene and render the sky of your image without clouds. Then add it as layer set to hard light or overlay or color, depending on what looks best and add the distance render of your full scene as mask to blend the strength. I used it on my "Flowering from the mist" image.
(_/)
