chohole opened this issue on Jul 21, 2003 ยท 15 posts
chohole posted Mon, 21 July 2003 at 1:25 PM
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
Rayraz posted Mon, 21 July 2003 at 2:47 PM
are you sure the transparency is set to blend transparency?
(_/)
chohole posted Mon, 21 July 2003 at 3:03 PM
Yes, and Ive turned of shadows on the hair, that doesn't help. I have never had any problems with this hair, or any hair in bryce before. Got to be the water, but how do I fix it.
Slakker posted Mon, 21 July 2003 at 3:13 PM
Looks fine to me...
electroglyph posted Mon, 21 July 2003 at 3:30 PM
Take the water plane up higher and decrease the texture scale to where it looks the same. The reflection will be diffused out by the distance. Even if its still there you can raise the plane enough to where the reflection from the fish will be out of camera view. That way you can keep the reflection sparkle. Click the little A channel ball on both the transparent and transparency channels in the material settings. The white part should go away.
isulaelu posted Mon, 21 July 2003 at 3:49 PM
maybe put some light above the surface, this help me in this case. did you try caustics reflections?
tjohn posted Mon, 21 July 2003 at 4:23 PM
This may be a dumb suggestion, but if you cropped the top of the pic a little, you could get rid of the fish reflections and still see the upper plane of the water.
Doublecrash posted Mon, 21 July 2003 at 5:24 PM
What about trying blurry reflections in the Premium Settings? Don't know if it works, but could be an idea. S.
shadowdragonlord posted Mon, 21 July 2003 at 7:17 PM
Chohole, are you using a volumetric (slab) plane or a flat plane? Also, what's the TIR set at, if you're using that effect? But I understand your frustration with the hair, it seems like Bryce can't really do 2D alpha transparency alongside Volumetric World. Do you have Volumetric World on? Just some ideas....
Aldaron posted Mon, 21 July 2003 at 7:42 PM
For the hair maybe try turning down the ambience.
electroglyph posted Tue, 22 July 2003 at 4:55 PM
electroglyph posted Tue, 22 July 2003 at 4:56 PM
electroglyph posted Tue, 22 July 2003 at 5:02 PM
shadowdragonlord posted Tue, 22 July 2003 at 6:21 PM
Good explanation there, Electroglyph. Chohole, we're all interested in seeing how your pic turns out! Please let us know if the problems got fixed...
Rayraz posted Wed, 23 July 2003 at 2:05 AM
If the water is a volume slab you can just turn off internal reflection to get rid of the shadows. An least I think that's how it works.
(_/)
