gstorme opened this issue on Jul 21, 2003 ยท 6 posts
gstorme posted Mon, 21 July 2003 at 2:43 PM
Just installed it but it does not work. I suspect something went wrong when authorizing it. Now the "License.exe" is outputting nothing. Anyone able to help me?
Georgous posted Mon, 21 July 2003 at 2:59 PM
MAKE SURE THE PLUGIN IS IN THE RIGHT FOLDER..iF ITS IN ITS OWN FOLDER TRY PUTTING IT IN THE MAX PLUGIN FOLDER OUT OF ITS FOLDER.
fauve posted Mon, 21 July 2003 at 3:48 PM
Have you tried contacting Reiss Studio directly? Their support is excellent. When I had a problem, they got an answer to me within hours (on a weekend, no less.)
aleks posted Tue, 22 July 2003 at 2:10 AM
you only get output ONCE from license.exe. if it does nothing then the installation and autorization was succesfull.
gstorme posted Tue, 22 July 2003 at 2:20 AM
I am in contact with Reiss now.
gstorme posted Fri, 25 July 2003 at 2:12 PM
Ok, the problem is solved. Thanks to Josh from Reiss who spend quite some time! I cannot pin-point the root cause, but what basically solved it was to re-install Poser 5 and Body Studio without Norton Antivirus installed. I do not blame any of the mentioned software since again I have no idea of the root cause of the problem.
