JetM opened this issue on Jul 23, 2003 ยท 4 posts
JetM posted Wed, 23 July 2003 at 12:22 AM
I saw the thread somewhere in this forum, but I can't find it again. THe gist is, you've got a texture map applied to an object--like a Poser model texture map--but you want to make it browner or tanner or something. I saw a thread where someone was using the A and B of the diffusion channel of a material. The texture map was chosen on A and I can't remember what was chosen on B. Was it just a simple DTS? I tried that, but I got a grayish brown. Hopefully someone can make sense of my ramble and either answer, or point me to the correct thread. Anyone?
JetM posted Wed, 23 July 2003 at 12:31 AM
Attached Link: http://www.castironflamingo.com/tutorial/tanline/index.html
If anyone's curious what I was rambling about...Rayraz posted Wed, 23 July 2003 at 7:29 AM
If you are using 2D-textures you can easily adapt the color in photoshop. That will give the best results. If you want to do it in bryce you can change the colors of the procedural by clicking on the second round button on the top of the texture channel. That should get you to the DTE. In the DTE you can ALT-click the colored dot's and adjust the colors to your liking. If you want to use a single color over a texture you can set it by ALT-clicking on the color-dot at the right of the diffusion, ambience, spec etc channels. Then you can click the tiny little triangle at the bottom right of the texture channel (where you set the mapping modes). you will find there's an option named 'decal colors' click it and your texture will get the color of the color-dot mixed through it.
(_/)
JetM posted Wed, 23 July 2003 at 11:05 AM
Hmm, decal colors. Didn't know about that one. I'll have to try it. Thanks!
