Subject: Vampire teet
Carolekara opened this issue on Jul 25, 2003 ยท 8 posts
Carolekara posted Fri, 25 July 2003 at 2:45 AM
How can I made a vampire teet in Poser on my caracteres?
sabretalon posted Fri, 25 July 2003 at 3:54 AM
Teet? I would assume teeth? I have seen some in freebies for V3
hauksdottir posted Fri, 25 July 2003 at 4:25 AM
Actually, "vampire teats" conjure up an amusing image of mama vampire feeding her young fresh warm blood from 6 nipples. Carolly
brandonc posted Fri, 25 July 2003 at 4:38 AM
lol
smiller1 posted Fri, 25 July 2003 at 4:55 AM
I misread the thread as Vampire Feet! :0) To answer the question, you could try creating a morph target for the teeth using a 3D modelling Application, tricky when it's in the mouth. I've only used Amorphium 1.0 and I couldn't select a tooth with that. If you create a sharp tooth and parent a couple to to the head, I don't believe it will move with the mouth.
hauksdottir posted Fri, 25 July 2003 at 5:59 AM
Hawktoey does have vampire teeth in Freestuff. I think they are for the milkids, but ought to work for anybody with some widgeting. I'm pretty sure that Traveler made teeth morphs, too.
KaraCarole posted Fri, 25 July 2003 at 6:26 AM
Thank but I just start in Poser 5
gryffnn posted Fri, 25 July 2003 at 6:53 AM
Hi, P5JudyMagic in my store here has a full set of 15 teeth morphs that include fangs and buck teeth, letting you adjust the upper or lower teeth placement in any direction, even side-to-side, or hide some or all. (Lots of other features too) P5DonMagic will have them too. HTH - Elisa/gryffnn
