Forum: Vue
Subject: Vue Animation Question
regaltwo opened this issue on Jul 26, 2003 ยท 2 posts
regaltwo posted Sat, 26 July 2003 at 5:14 PM
Hi there. I am just starting to do animation in Vue, and it seems fairly straightforward, but I do have a question. Can anyone tell what settings I'm supposed to use in Vue (resolution, size, frames per second, and so on...) for something that will ultimately be edited in Premiere and end up on VHS (to be played on a U.S. set, if that matters)? Thanks.
Parkie posted Sat, 26 July 2003 at 8:59 PM
Hi, I'm not in the USA but to get the frame size check in premiere for the size of the frames you are using. This is shown in the rendering screen and preferences. Also the rest of the options you need like the pixel format and frames/sec. In my case the frame was 720x576. I have done a couple of small start and end sequances. Since I use PAL format it was rendered at 25 frames/sec and changed the pixel shape to suit Pal and rendered in Final mode. I found that for what I was wanting final mode when put on Video was fine. I am only doing "home moves" type productions. Have fun Neil
