Subject: Followup to "...World of Hurt..."
HAE_Inc opened this issue on Jul 26, 2003 ยท 7 posts
HAE_Inc posted Sat, 26 July 2003 at 5:23 PM
**After I click on the above thing a box comes up which says it isn't a valid poser thing, what's the story?
**Thank You
maclean posted Sat, 26 July 2003 at 5:34 PM
Can you tell us exactly what the message says? And what file it is - Character, Pose, Prop? It could be one of several errors. mac
HAE_Inc posted Sat, 26 July 2003 at 6:02 PM
**Well, it's a clothing texture, whatever category that falls under and when I double click on it to load it, it says its not a valid poser file. The texture is from the "Active Wear denim days" by daz.
hae%20inc.jpg**
dlk30341 posted Sat, 26 July 2003 at 6:02 PM
You know...I get that same message with an HR2 file called Alice Hair....I tried to open it up in word & just got garbage. Not a valid Poser file.....DAMN
lalverson posted Sat, 26 July 2003 at 6:22 PM
Very likey it is a mac made poser file it has some addtional info at the top and bottom of the file that need removed first, it is a pain to do but can be done. Or better still download the pc version of the item. Most folks thata offer free stuf normall include wheter it is a mac or pc version.
maclean posted Sat, 26 July 2003 at 6:55 PM
If you look at the file in a text editor, like notepad, you should see something like the lines below. It may be quite long, depending on how many materials are in it, but the important parts are the beginning and end. They should look like the one below. If there are extra braces - { - or lines missing, you can correct it. Resave it under a new name and try it first though.
begins like this
        version
                number 4.01
        figure
                material inset
                        KdColor 1 1 1 1
                        KaColor 0 0 0 1
continues with more lines and materials
ends like this....
                        ReflectionColor 1 1 1 1
                        reflectionStrength 1
mac
maclean posted Sat, 26 July 2003 at 6:59 PM
Hae, In your other post, you had error messages about newer version files. The code above says this
        version
                number 4.01
Your files will say 'version 4.2'. Change that line to 'version 4.01' and they'll work fine.
mac
