Forum: Photoshop
Subject: Realy Importent!
DarkSaint opened this issue on Jul 05, 2000 ยท 6 posts
DarkSaint posted Wed, 05 July 2000 at 7:27 AM
I wont to write a tutorial, and i nead some screen shuts, to mack it isiar to anderstend. How can i do that? (Scren shuts)
cote posted Wed, 05 July 2000 at 12:38 PM
If you are working on a PC, you can hit the "Print Screen" button on your keyboard when you are at a screen you want to capture. Then go into Photoshop and create a new document. You should notice that by defualt, the canvas size is set to your monitor resolution. After you have created the new document, use the "Paste" function and you will have your screen shot. You may have to crop it. There are also many screen capturing programs available, WinGrab is a free one you can get off of the web.
dlm posted Wed, 05 July 2000 at 1:13 PM
I did not know this tip.I,ve just tried it and it works fine.One of those little bits of information you come across now and again and think,"Hey that is so great....why did I not know this".Thanks Cote.Made my day.
DarkSaint posted Thu, 06 July 2000 at 3:46 PM
Thank you!!! It helped a lote!
TriTeq posted Tue, 25 July 2000 at 2:54 PM
Also, if you are capturing just a dialog box in a program, and are using Windows, try holding down the Alt key + Printscreen. It should capture only the dialog window that is in the foreground. I'm not sure if holding the Option key + Printscreen works on a Mac.
Caligula posted Wed, 02 August 2000 at 4:01 PM
Command Shift 3 or command shift 4 does the screen shot thingy on the Mac. There isn't a print screen button on a Mac keyboard.
