Forum: Photoshop
Subject: Printing photos, automation?
jchimim opened this issue on Aug 01, 2003 ยท 9 posts
jchimim posted Fri, 01 August 2003 at 7:54 AM
I frequently have 30+ photos in one directory, and would like to print one copy of each. Usually print 4"x5.33", so get four to a sheet. Is there any easy way to organize a directory full of photos into 8.5x11 sheets, four to a sheet? The "automate - photo package" make four copies of each one. The "automate - contact sheet" makes each copy small (wastes a lot of expensive paper.) Doesn't have to be a photoshop action or plug-in, but would like easy and cheap. THANX!
retrocity posted Fri, 01 August 2003 at 10:28 AM
Do the photos need to be resized or anything first??
retrocity
jchimim posted Fri, 01 August 2003 at 11:22 AM
Yup, looking for something that will do all the work. :) Actually got a response posted at dpreview.com recommending "power albums," downloadable from http://www.torry.net/util_graphics.htm . Neat little progam, easy to use, powerful, and free. Thanks!
dreamer101 posted Fri, 01 August 2003 at 12:31 PM
What you could have used in Photoshop was File > Automate > Contact Sheet II. There you can set the number or columns to 2 and rows to 2. They can be captioned or not.
jchimim posted Fri, 01 August 2003 at 2:19 PM
But they waste a lot of "real estate" on the paper...
jerr3d posted Thu, 21 August 2003 at 5:49 PM
I know you said it doesn't have to be an action, but that is the solution. You have to write an action to make the sheet with four different pictures on it.
jchimim posted Thu, 21 August 2003 at 5:52 PM
"power albums" is actually a better/easier solution.
jerr3d posted Thu, 21 August 2003 at 5:54 PM
never heard of it, what is is?
jchimim posted Thu, 21 August 2003 at 6:40 PM
Attached Link: http://www.angelfire.com/ga/bazuka
It's an album creator, but it's neatest feature is auto arranging up to 8 different images on one sheet for printing. Fairly easy to use, most things accessed from right-click instead of menus. The web page is at link, but on angelfire so maybe not easy to get to. There's an older version at http://www.torry.net/util_graphics.htm
