Porthos opened this issue on Aug 02, 2003 ยท 12 posts
Porthos posted Sat, 02 August 2003 at 11:37 AM
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD
7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
JetM posted Sat, 02 August 2003 at 11:46 AM
Havn't used it for awhile, but I think you're supposed to parent the figure to Mike, not conform it. It had something to do with the skirt. Do you still have the readme?
Porthos posted Sat, 02 August 2003 at 11:56 AM
Yes I've read the readme and it does say that conforming causes the shins to over rotate! I guess I must parent the skirt! Thanks!
7770
AlleyKatArt posted Sat, 02 August 2003 at 12:35 PM
The skirts aren't meant to conform. The male clothes aren't that great, but the female one can conform if you use the short transmap.
Kreations By Khrys
Momcat posted Sat, 02 August 2003 at 1:38 PM
The female one conforms just fine. I'm using on Stephanie Staxx right now. You just need to run it through the Tailor first for Steph though, or the hip/abs don't fit right. Use the body handles (via the shin parameter dials) to pose the skirt.
Porthos posted Sat, 02 August 2003 at 3:03 PM
Thank you! I found that Vicky conforms and Mike's need to be parented! Trying to get the hang of posing it! :P
7770
Porthos posted Sat, 02 August 2003 at 3:20 PM
7770
AlleyKatArt posted Sat, 02 August 2003 at 3:23 PM
I find the male skirt rather clumsy, at best. However, you've got it looking /good/.
Kreations By Khrys
Lyrra posted Sat, 02 August 2003 at 4:23 PM
well its an awkward piece of clothing to begin with ... you're not really meant to move around that much in it
AlleyKatArt posted Sat, 02 August 2003 at 4:28 PM
True. But it's clumsily built, as well. It doesn't scale, at all, and if you try, you get horribly results. The idea was a good one, but the way it was done wasn't.
Kreations By Khrys
bijouchat posted Sat, 02 August 2003 at 8:22 PM
hrm, idea floats through my mind to make it into a one piece obj and try it in the P5 cloth room.
Jenny_Lea posted Sun, 03 August 2003 at 2:17 AM
keep in mind that the eegyptian skirts are constricting and were never used for action like the second pic poose ^_^ just a point not a critisim
