krbtv opened this issue on Jul 07, 2000 ยท 5 posts
krbtv posted Fri, 07 July 2000 at 6:24 PM
I have to characters in my document window (girl and boy). Everytime I select the girl and try to make her move the boy moves. What am I doing wrong?
Lemurtek posted Fri, 07 July 2000 at 6:31 PM
Are you selecting the caracter and then trying to drag them around in the Window? This can be a pain, try selecting and using the Dials to position her.
Viomar posted Fri, 07 July 2000 at 9:47 PM
Could also be as simple as "Parented Figures"! Open the Hierarchy editor & Check if one of them is parented to the other. If so parent the "Child" one to "Universe"... Marc
Cage posted Fri, 07 July 2000 at 10:02 PM
For some perverse reason or other, Poser sometimes likes to switch characters, usually immediately upon loading a new one to a scene. I thought this had been addressed by the Patch, but it has happened a few times since I installed. If this is the problem, change the character names from the default "figure 1", etc., in the Hierarchy Editor.
Cage can be an opinionated jerk who posts without thinking. He apologizes for this. He's honestly not trying to be a turkeyhead.
Cage had some freebies, compatible with Poser 11 and below. His Python scripts were saved at archive.org, along with the rest of the Morphography site, where they were hosted.
amp-three posted Fri, 07 July 2000 at 11:08 PM
I have recently started using P4 and have come across this problem as well. The best advice i can give is.... Specticles, Testicles, Wallet, Watch. :) no honestly, an ameteur-yet-easy-to-grasp way to do it is since you have two characters, pick one. go on, it isnt that hard. now, move that one to where you want it to be. For the second character, try rotating it to face the same way as the first, then use the "X/Y/Z trans" dials to position him. then make the little alterations. Im sure a pro could do it quicker and easier in about 5 min, but id rather (ok ok no i wouldnt :) be the one to say, "all in a nights work!" ..->[ aMP-3 ]<-..
