majesticartist opened this issue on Aug 04, 2003 ยท 6 posts
majesticartist posted Mon, 04 August 2003 at 6:58 PM
majesticartist posted Mon, 04 August 2003 at 7:27 PM
forgot to say Im using Poser 4 lol
onnetz posted Mon, 04 August 2003 at 8:20 PM
Handle every stressful situation like a dog.
If you can't eat it or play with it,
just pee on it and walk away. :-)
I wouldnt have to manage my anger
if people would manage their stupidity......
onnetz posted Mon, 04 August 2003 at 8:26 PM
forgot to say thats a lousy render of a nice bathroom from sams3d.com.. :-)
ockham posted Mon, 04 August 2003 at 9:38 PM
Also, try the Hither dial on the camera. If something is too close, the camera will cut it off, and you can sometimes fix that with the Hither dial. ------ Smart prop: The prop has to be a single object, not a parented combination. For instance, the Poser primitives (box, cone, etc.) are single objects. Some custom-made PP2 files are combinations. Bring in the prop from the library, then parent it to the head or whatever. (Head is parent, prop is child.) Be sure the prop is the selected item. Then choose some Prop folder in the library and hit the + sign at bottom of the folder. Do not hit the "Select Subset" button. You should see a box that asks whether to make this a smart prop. Choose Yes, and give it a name. ---- Showing beneath the water: Just make the water prop transparent. You will have to fiddle with the Transparency Max and Min sliders to make it look right.
SAMS3D posted Tue, 05 August 2003 at 4:25 AM
onnetz I like it......glad to see it being used :-)Sharen
