Forum: Bryce
Subject: Screen Shot Problems - Please Help!
TheBryster opened this issue on Aug 07, 2003 ยท 22 posts
TheBryster posted Thu, 07 August 2003 at 7:14 AM
OK! I give up! How do you guys do screen grabs? I've been trying and failing with Corel Capture 10. It doesn't seem to want to know. I want to grab Bryce screens to demonstrate things I've found but fail miserably. I'm now at my wit's end. Help much appreciated. Thanks The Bryster
Gog posted Thu, 07 August 2003 at 7:36 AM
I generally just use alt-prtScn then paste into photoshop!! are you on a Mac or PC?
Quest posted Thu, 07 August 2003 at 8:14 AM
Bryster, when you have the screen you want to grab up, press the "Print Screen" key on your keyboard. Then open Photoshop, go files>new and click OK(should be the same size of your present desktop screen size automatically, 800x600, 1024x768, 1280x1024...whatever). Once the canvas is up go Edit>paste and presto! One screen grab. Now you can fiddle with it all you want.
Rayraz posted Thu, 07 August 2003 at 8:15 AM
Usually the printscreen button works fine. Then I go into PSP and press Ctrl-V to load the screengrab to a new image. If for some reason it doesn't work there's probably some free screengrabbing software at download.com
(_/)
electroglyph posted Thu, 07 August 2003 at 9:01 AM
Like they all said..... If you have PaintshopPro 7 or better it has an image aquire command with a screen capture function. Lots of nice extras including a programmable hot key you can choose or a timer if you need to get back to the screen and do something before you grab it. There is also an option to grab the cursor.
Zhann posted Thu, 07 August 2003 at 9:20 AM
Yeah, in PSP, under File Menu, import/screen capture/start, just set up your hot key first, then all you do is hit the hot key to capture, PSP will sit on your task bar until your finished, then just restore it and your captures should be there, just resize them and save...
Bryce Forum Coordinator....
Zhann posted Thu, 07 August 2003 at 9:23 AM
see above....
Zhann posted Thu, 07 August 2003 at 9:24 AM
Lol, had to use printscreen to capture the PSP capture, seems it won't capture itself!...;]
tjohn posted Thu, 07 August 2003 at 9:38 AM
If you have Photoshop, you shouldn't have to paste, under "New" there is "from clipboard". The clipboard is where the "print screen" image goes. When you choose "from clipboard, the image (screen size) will appear.
Incarnadine posted Thu, 07 August 2003 at 11:21 AM
Corel's PhotoPaint also has the File/New from clipboard capability. (at least in v9 it does, should still be there in v10)
Pass no temptation lightly by, for one never knows when it may pass again!
pakled posted Thu, 07 August 2003 at 12:19 PM
I feel silly, I've been doing printscreen caps and pasting into Paint..works ok, but it'll be our little secret, right?..;)
jasonmit posted Thu, 07 August 2003 at 1:42 PM
Now if I could figure out how to grab screenshots when a DVD is playing on my PC. There's some great shots in the movie "The Pianist" I'd like to try to recreate in Bryce. But when I did printscreen, all I got was a black image.
Colette1 posted Thu, 07 August 2003 at 4:25 PM
Pakled, I do screen caps the same way.:)
Quest posted Thu, 07 August 2003 at 6:42 PM
Jasonmit, sometimes the software package used to view the DVD also allows you to cap frames. In some cases it must be a registered full version of the software not a limited edition. TJohn thanks for the tip, I've never captured using that technique. I'll try that way next.
Zhann posted Thu, 07 August 2003 at 8:23 PM
I tried with a 'capture software' to get a screen shot of a DVD, all I got was undulating noise....there may be something in place to prevent it...I just use my digital camera, pause the scene, snap, voila, screenshot...
TheBryster posted Thu, 07 August 2003 at 8:26 PM
Many thanks, Guys! I must behaving a dumb day or a senior moment...I'll try all this out soonest...as I have PSP7 which I prefer to CoralDraw. Thanks once again The Bryster
jasonmit posted Thu, 07 August 2003 at 8:27 PM
Zhann, I thought of that. I'll maybe have to botrrw my digital camera (my church uses it more than I do).
TheBryster posted Thu, 07 August 2003 at 8:30 PM
Well that worked just fine. Well done, you Guys!
Zhann posted Thu, 07 August 2003 at 8:39 PM
Jasonmit, be sure the flash (if it has one) is diabled, mine's on by default and sometimes I forget, FLASH, then I get an nice bright light photo...8D
JC_01 posted Thu, 07 August 2003 at 11:46 PM
lol Zahnn, isn't it funny how a program with a built in screen cap won't screen cap itself? makes making a psp tutorial with pictures a pain...LOL Also, you can set in psp7 and 8 the screen cap set up options to grab multiple screen caps....as long as you don't go back into the psp window till your done, you can keep browsing and capping without having to go back and start a new cap....but once you open the psp window again, you gotta start a new screen cap again...
Zhann posted Fri, 08 August 2003 at 12:25 AM
You know I've been working on my ocean waves tutorial and as I'm doing stuff in Bryce I take a screen cap, only when I get back to PSP, I can't remember which pic illustrates what part of the tut, some are obvious but others I'm scratching my head thinking 'now why did I capture that?'...;]
TheBryster posted Fri, 08 August 2003 at 7:25 AM
Jan: You must be getting old! I have the same problems..LOL I keep thinking....why did I logon to the 'REND......
