Subject: ruffles!! why wont it work
LadyBea32 opened this issue on Aug 08, 2003 ยท 4 posts
LadyBea32 posted Fri, 08 August 2003 at 3:06 PM
why is it so hard to get these darn ruffles to work on this dress? everything else works fine but these little ruffles are a pain in my poser person an my rump. anyone know how to make these little buggers work correclty? in the simplist of poses the ruffles still stick out on the bottom. only way they seem to work is if the arms dont go down.
LadyBea32 posted Fri, 08 August 2003 at 3:08 PM
another part of it, that split on the bottom was fixed already
bloodsong posted Fri, 08 August 2003 at 4:21 PM
heyas; adjust the joint parameters on the dress's arms so the green arms of the z rotate X enclose the bottom of the ruffles. um, if you need a more detailed explanation, let me know. :)
LadyBea32 posted Fri, 08 August 2003 at 4:31 PM
i found out, the reason why they dont work right is cause the are right at the joint of the shoulder and arm. so i got mad and ripped it off the dress. i am not the one that does the poser parts of these things. but i well pass your info onto my helper. maybe he could try that as well. thank you much hon bea
