satfj opened this issue on Aug 09, 2003 ยท 4 posts
satfj posted Sat, 09 August 2003 at 5:35 PM
When I render to a file, what format should I save as...BMP, RGB, JPEG or? Assuming that I will take that image to an image editor such as Photoshop to compress or edit for web, or what have you. In otherwords wich file format will give the truest of quality. Thanks
raven posted Sat, 09 August 2003 at 5:36 PM
If you save as .tif or .psd, you also get an alpha channel if you need it.
Little_Dragon posted Sat, 09 August 2003 at 6:23 PM
Same with .png format, if that's available for you.
satfj posted Sun, 10 August 2003 at 1:01 PM
When would you use RGB as a save as method though? Does it give you richer colors say for compressing to monitor viewing rather than printing?
