krbtv opened this issue on Jul 11, 2000 ยท 5 posts
krbtv posted Tue, 11 July 2000 at 7:07 PM
The document window shows the cartoon view. When I render it then the render is 3D like regular texture view. What am I doing wrong. (The make AVI will show up like a cartoon)
Ghostofmacbeth posted Tue, 11 July 2000 at 8:01 PM
There is no way that I know to render AND keep the cartoon view .. the best you can do is anti-alias it ... Render always does a 3D view
Krel posted Wed, 12 July 2000 at 6:47 AM
When you render to an AVI or bitmap, select "use current display settings" and this will retain the cartoon effect....BTW you can very high quality cartoon images rendering to a movie, any size you want......good luck.... Krel
arabinowitz posted Wed, 12 July 2000 at 9:07 AM
The problem withthe cartoon render is that it doesn't come out with textures, so that your figure is one uniform color (unless each material has a seperate color). Is there a plugin for Photoshop or aftereffects, or a setting (in the sketch render) that does a good cartoon-like render after the image is made? This way you could have the cartoon-like image, with more color, and none of those ugly shadows.
Krel posted Thu, 13 July 2000 at 6:29 AM
See my new post.....mermaid cartoon
