darhorn opened this issue on Jul 13, 2000 ยท 10 posts
darhorn posted Thu, 13 July 2000 at 11:03 AM
I had posted a note a week ago about memory problems with Poser 4.. and I never did get it fixed.. for example, I tried to load a pz3 this morning and 20mins later it still hadnt loaded and my system was completely out of memory.. considering that I had 512 MB of RAM, it shouldnt happen.. So I backed up the directory and installed P4 in a new directory and tried to open the same file, it loaded perfectly with no problems... now, before I install the patch and start moving files back in, has anyone had a problem similar to this? I dont want to move something in that will cause the problem anew.. Also, what was happening was that if a texture map was not found, all I got was an error message, though with the new install, it actually pops up a dialog so that you can specify the location of the map... is this a result of the patch? Hoping someone out there has an answer :) Thanks Darrin
