Neyjour opened this issue on Aug 15, 2003 ยท 6 posts
Neyjour posted Fri, 15 August 2003 at 11:39 PM
I'm brand new to Poser. I bought Poser 4 and Pro Pack, ended up with faulty software, and am now waiting to get an exchange. What I'd like to know is, when the new one arrives, should I start out with just Poser 4 or install both? Thanks! Ney
"You don't know what we can see
Why don't you tell your dreams to me
Fantasy will set you free." - Steppenwolf
Crescent posted Fri, 15 August 2003 at 11:53 PM
I'd install both P4 and PPP. PPP will make your life easier. Many free and commercial items use .jpg files for BUM files. (BUM files create the illusion of indentations when rendering.) If you have PPP, you can use them right away. They're smaller and easier on system resources. If you have P4, you'll have to convert each one to a .bum file in Poser which takes a minute or two and will suck up a lot more hard drive space. PPP also does not create .rsr files in the Geometries folder. This may not mean much, but the upshot of it is you use less hard drive space and there's a lot less chance of the mesh going funny and doing all sorts of strange things. (One of the most common fixes for P4 weirdness is to delete the .rsr file from the Geometries folder. If you have PPP or P5, you won't have to worry about that.) There's a lot of other reasons to use PPP right away if you have it, but those are two easy ones to explain. Cheers!
aprilrosanina posted Sat, 16 August 2003 at 10:31 AM
Attached Link: http://market.renderosity.com/~pzr/backroom/index.htm
The Poser "backroom" has a great deal of very helpful information for new Poser users. Especially check out the FAQ first - one of the answers gives details on PPP's benefits!Neyjour posted Sat, 16 August 2003 at 11:42 AM
Crescent and April, thank you very much for your help! :)
Odiemance posted Sat, 16 August 2003 at 11:50 AM
You always want to get as much practice with as new a version as you can afford. Sometimes, when you ca'nt replicate a technique as well in a newer version(Due to lack of experience,) it is ok to to have a second installation(Of the former version) working, but that would be your only reason.
EricofSD posted Sat, 16 August 2003 at 2:36 PM
and don't forget to run the patches. I would presume that they are included in your P4/pp purchase but just in case, they are over at the CL web site.
