---Gallego--- opened this issue on Aug 16, 2003 ยท 9 posts
---Gallego--- posted Sat, 16 August 2003 at 3:29 PM
how can i do to conform the daz changing ponytail to v3?? every time i put conform..it goes to the floor!! i've tried on sara spititelling and is the same!!! cant pick up the hair from the floor!! PLEASE HELP!!
Dagon posted Sat, 16 August 2003 at 3:40 PM
it's not a conformable item. Just parent the hair to Vic' head. hope it helps
Puntomaus posted Sat, 16 August 2003 at 3:48 PM
Like Dagon said, it is not a conforming item. When you have conforemd it to V3 or any other figure and it does weird things just click Conform to again and select None from the list. That will put your item back into it's default position. With Vicki's changing Ponytail you simply select the body or the base of the hair, go to Figure - Set Figure Parent and select the head of your model. After that the hair stays in place when you pose your model.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
---Gallego--- posted Sat, 16 August 2003 at 4:31 PM
yes but when i load the hair it stays floating above vics head
pzrite posted Sat, 16 August 2003 at 5:21 PM
You have to manually position it first, then parent it to the head.
FyreSpiryt posted Sat, 16 August 2003 at 5:49 PM
Try checking the readme. It has very nice instructions on how to do this.
gryffnn posted Sat, 16 August 2003 at 7:36 PM
Once you have adjusted the hair manually to fit V3, with the trans and scale dials, save it with a new V3 name. Then you can load the hair to V3 and it will be positioned correctly. HTH - Elisa/gryffnn
Turtle posted Sun, 17 August 2003 at 9:48 AM
Yes you do it with the dials. With the Sara S. you dail size to what ever your Sara model shows. Mine I use small person and that's 80% and it fit my little woman perfect.
Love is Grandchildren.
Puntomaus posted Sun, 17 August 2003 at 1:47 PM
When you like to use the Ponytail with SaraSpriteling it's really easy to make it fit.
Load the hair, then you go to the SaraSpriteling Pose folder and click with the hair selected on !Deform Libary Hair and after that (with still the hair selected) on !!Instant Human or !!Instant Elfling (depends on what morph you have used on Sara) and that will put Vicki's Changing Ponytail perfectly on her head. All you need to do is parent it to her head that it stays there when you move her around but you do not have to use the dials to get it into position.
Btw, using this poses will make every hairfile fit to Sara.
Every
Assange
