Roch222 opened this issue on Aug 16, 2003 ยท 6 posts
Roch222 posted Sat, 16 August 2003 at 4:11 PM
when you want to layer your different scenes that you have rendered and put it all togethr in PSP or whatever... do you only render one scene with a sky do you render your objects on white sky ?????? i need layering tips or blending tips thanks roch222
antevark posted Sat, 16 August 2003 at 4:12 PM
I'd recommend putting the same sky on all of the layers, that way reflections, transparency etc. work properly.
Rayraz posted Sat, 16 August 2003 at 4:18 PM
Not only is it important for reflections, rendering with the exact same sky gives you the exact same lighting conditions too.
(_/)
Roch222 posted Sat, 16 August 2003 at 4:59 PM
but what about layer settings? Im having trouble blending, either one layer dominates or looks washed out etc..
antevark posted Sat, 16 August 2003 at 5:38 PM
Must be exactly the same lighting, sky settings, and make use of mask rendering.
EYECON posted Sun, 17 August 2003 at 12:52 AM
antevark is right, use the mask rendering... chose the biggest of your object, EG terrain, and do mask rendering and render it... the sky must be the same... or else your going to mess up bigtime (actually i learned that the hard way)
