Ajax opened this issue on Aug 20, 2003 ยท 16 posts
Ajax posted Wed, 20 August 2003 at 5:42 AM
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
Dale B posted Wed, 20 August 2003 at 8:28 AM
Haven't had a chance to sit down and haul out Davo's MadlabII set props yet (or been struck with any real inspiration...yet), but the little bit of test fiddling I did with it definitely has given me the rumblings of ideas. And it seems to work very well in the quickie tests.
Jackson posted Wed, 20 August 2003 at 2:53 PM
Ajax posted Thu, 21 August 2003 at 6:55 AM
Thanks guys. Jackson, I am indeed planning to update my old tentacle pack. I'm hoping to do it before the end of the year, but I have another two products that have to be updated before I get to it and my boss said today that she expects me to be doing a lot of travelling around the country for the rest of the year, same as last year, so we'll see what I get time for between now and 2004. When I do update the tentacles, the main focus will be on providing newer, better meshes and textures. I plan to turn it into a much larger and more extensive pack with a number of different types of tentacles. The update will be free - at least for people who bought the tentacles here at Renderosity. I'll have to negotiate with the other stores to see if they'll support me to distribute updates. I don't have any easy way to contact old customers from the other stores, so unless they agree to use their records to do it for me, I don't have any easy way to distribute the update.
Ajax's Store -
Send Ajax a message
Jackson posted Fri, 22 August 2003 at 10:25 AM
That's great news! And thanks again for this...I'm still playing :)
JFStan posted Wed, 31 December 2003 at 5:50 PM
I scaled and posed the tube, turned on IK and parented the end to the helmet, and then THIS happened! I can't scale it back into shape, nor will it return to normal if I detach it and zero it out.
This also happened with a tube I made and boned myself, so it may not be EasyPose Tube related, but I was hoping someone would know what's happening here. Thanks!
-=JFStan=-
JFStan posted Wed, 31 December 2003 at 9:12 PM
I found an interim solution to my problem.. I just turned off visibility for the end segment. -=JFStan=-
Ajax posted Fri, 02 January 2004 at 6:58 AM
Attached Link: http://www.free-cartoons.net/t/thundarr_the_barbarian/
Hmmm....I'm not sure what's going on there. Sometimes Poser just does weird things, especially if you have parenting, scaling and IK all happening at the same time. The first thing I would do is check whether there's a curve dial in that segment and set it to zero if there is. Apart from that, I don't know what to suggest :-(
Ajax's Store -
Send Ajax a message
Ajax posted Fri, 02 January 2004 at 7:01 AM
Attached Link: http://www.free-anime.net/k/kokoro_library/
Arrrgggg. How did that link get in there? This has happened to me a few times recently.
Ajax's Store -
Send Ajax a message
dialyn posted Fri, 02 January 2004 at 7:06 AM
Attached Link: Community Forum on unwanted links
You may want to delete the message and repost.JFStan posted Fri, 02 January 2004 at 10:36 AM
No problem about the links.. I think they SHOULD release Thundarr on DVD! :)
-=j=-
PS - No Curve dial on the last segment.
millman posted Fri, 02 January 2004 at 11:30 AM
Ajax, download and run AdAware or Spybot. They'll clean it up. Better yet, get both. THink adaware is from http://www.lavasoft.de Adaware wants money to block the spy or hijack proggys, Spybot included "innoculation" as a freebie. Both are freebies, BTW.
Ajax posted Fri, 02 January 2004 at 6:08 PM
Attached Link: http://www.art-5.com/literature/authors/i/issa/
I've run both AdAware and Spybot but neither of them found anything at all. I just re-ran them a few minutes ago with the updated definitions and still nothing is showing up. I'm also suffering from a pop up that keeps trying to sell me anti-popup software (grrrrr). Neither Spybot nor AdAware can fix that either. I don't know if it's related.
Ajax's Store -
Send Ajax a message
millman posted Fri, 02 January 2004 at 8:48 PM
Did you try deleting the contents of the temporary internet files? I keep mine set to delete them on exit from internet exploder (IE). But then, i also block Javascript, and only the barest of the html files makes it. In the tools>options>advanced, I also disabled install on demand. It all seems to help somewhat. I should mention though, this computer is only one of seven that I use, and it's sole function is the netbox. The others aren't on line.
Ajax posted Sat, 03 January 2004 at 1:42 AM
Attached Link: http://www.free-music-1.net/j/rick_james/
Well, I've just deleted pretty much everything from my temporary internet files. We'll see if that makes any difference.
Ajax's Store -
Send Ajax a message
Ajax posted Sat, 03 January 2004 at 1:47 AM
Attached Link: http://www.free-movies-1.net/m/mean_streets/
I guess that's a no :-(
Ajax's Store -
Send Ajax a message
