mit123 opened this issue on Aug 20, 2003 ยท 8 posts
mit123 posted Wed, 20 August 2003 at 7:25 AM
Last night while I was working with Poser I clicked something near the first drop down menu, not sure what as my mouse slipped. Then Poser shutdown.
When I tried to open Poser after that I kept getting an: XML error at line... not well formed error log is being created, type of message.
This meant that I couldn't open Poser up whatever I tried.
Eventually I found by looking at files created in last 24 hours that the offending file was my Library prefs. I ended up renaming an extra Runtime that I'd created and amending the Library prefs file to reflect this name/path change.
Pheeew it worked out fine in the end.
Does anyone know how I managed to get the error up in the first place, what on earth did I do wrong?
Thanks
Mit
joffry posted Wed, 20 August 2003 at 10:05 AM
this happens when poser crashes. what I did was make a copy of that xml library file and when I crash I just move it back. Poser will automatically rebuild it after most crashes, but I've noticed that it defaults back to when you first installed and you have to re-enter all the addtl runtime folders you added.
mit123 posted Wed, 20 August 2003 at 12:07 PM
At least its a relatively straightforward process to sort out eh?
joffry posted Wed, 20 August 2003 at 12:33 PM
yes definitely... once I figured it out.:)
pakled posted Wed, 20 August 2003 at 1:21 PM
xml is mainly html with a few more rules..;) what that has to do with Poser is beyond me..'not well formed' means that the code isn't set up by XML rules, like missing end tags, etc.
quinlor posted Wed, 20 August 2003 at 1:50 PM
Posers stores its preferences etc. in xml files. When Poser 5 was first released, this problem did happen with some special Characters (like & )in libary path names.
It was fixed in SR 1 ore 2.
Stefan
mit123 posted Wed, 20 August 2003 at 4:23 PM
quinlor, that would explain it. I re-installed poser just last week and hadn't gotten round to the srs.
EricofSD posted Wed, 20 August 2003 at 9:44 PM
The SR's will overwrite some of the xml files IF they are the native date/stamp ones. So, don't manually modify your xml's. Also, maybe just rerunning the patch will fix the problem depending on which xml was damaged.
