JAFO opened this issue on Jul 17, 2000 ยท 8 posts
JAFO posted Mon, 17 July 2000 at 6:33 PM
Y'all have a great day.
JAFO posted Mon, 17 July 2000 at 6:45 PM
OH just made up a song... thank you MAZA ...THANK you MAZA... for your WONDERFUL MTmirror thingie... ......So what if i cant sing...i love this thing...lol JAFO oh by-the-by to mirror vickis collars you have to export both collars as a base ...then export both collar Targets as single object from rhino or whatever ....do the mirror...then import your base back into poser...add morph... export as object...then explode mesh and import each piece back into poser as usual... lota stuff to do...but better than doing both sides manually...
arcady posted Mon, 17 July 2000 at 6:56 PM
How do you explode the mesh? I figured the rest of it.
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
JAFO posted Mon, 17 July 2000 at 7:05 PM
arcady , im only familiar with Rhino and MAX both of these programs have options for seperating meshes
Quikp51 posted Mon, 17 July 2000 at 7:25 PM
Hey that's pretty cool. Good work.
Jaager posted Mon, 17 July 2000 at 11:15 PM
I do the morphs on a comlex: R&L Collars plus chest in RDS opened as a single mesh. Still only doing the morph on one side. You must then remove the chest in Compose, leaving the 2 Collars. You can also isolate a copy of the morphed collar at this point. Open the 2 Collars in MirrorMT and mirror the morph. Now, because Compose will not accept the stripped morph that comes out of MirrorMT , it is necessary to copy the "v" data from the mirrored file and paste it over the "v" data in the pre-mirrored file. Compose will accept this and allow isolation of the mirrored Collar morph. This is also a method that works for the Buttocks. ( I have had nothing but bad experiences in using the export function in Poser as a source for groups for morphing. ) They move or scale and I can cut-n-paste more quickly than it takes for Poser to open.
LoboUK posted Tue, 18 July 2000 at 4:56 AM
Now that is cool JAFO, very very cool. Paul
PilotHigh posted Tue, 18 July 2000 at 9:50 AM
WOW, and WOW again!!!!!! JAFO you are the greatest. I tried to squish and squash them puppies with morphs but they ended up looking like mashed potatoes. This is just amazing. Thank you, thank you, thank you. Are you going to put it up in FreeStuff? Aeriol ps: sorry for the misspelling in the previous post. It's not an everyday word and I should have checked the spelling myself. Sorry again.
