HAE_Inc opened this issue on Aug 23, 2003 · 10 posts
HAE_Inc posted Sat, 23 August 2003 at 5:47 PM
Hi Again, Well, I just had a thought, how do I make a reflection map. Now if its too complicated you don't need to explain it b/c i probably won't get but i'd really like to know. Just forget that last sentence. I'd like to know, or do I just download a reflection map or what. Oh yeah, I want to be a reflection map so i can make a poser square to metally Cheers
cooler posted Sat, 23 August 2003 at 5:54 PM
there are gold & silver reflection maps included with poser (p4 at least but I assume they should be in 5 also) In poser 4 they can be found in... Poser4/Runtime/Reflection Maps
wheatpenny posted Sat, 23 August 2003 at 5:56 PM Site Admin
Also quite a few Poser props, etc... come with them, so you probably already have several.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Mason posted Sat, 23 August 2003 at 6:01 PM
Also just about any texture can be used as a reflection map. some look better.
SamTherapy posted Sat, 23 August 2003 at 6:07 PM
You should try using a very high contrast fractal as a reflection map. It's not always immediately useful, but the effects can be "interesting". :)
DraX posted Sat, 23 August 2003 at 6:16 PM
Attached Link: Morph World 3.0
The best method I've found is up on Traveler's site, in the tutorials section.PhilC posted Sat, 23 August 2003 at 8:13 PM
Reflection maps are just images. Its a programming shortcut. Instead of working out the actual ray traced reflections it uses the reflection map instead. For example a picture of a wall with a window would work well as a reflection map on a glass vase in a room.
Those of you that have the recent Swing Zone set may like to look closely at the shiny belt. You are now looking at a picture of my yard :)
SamTherapy posted Sun, 24 August 2003 at 6:14 AM
Phil, the Swing Zone passed me by. How, where, what, please. IM me if you feel uncomfortable about posting for commercial products on here.
PhilC posted Sun, 24 August 2003 at 6:27 AM
elizabyte posted Mon, 25 August 2003 at 7:44 AM
You can use any image for a reflection map. The effect will depend on the image, of course. I second the idea of using a fractal. It does give some VERY interesting reflective effects. Best suggestion is to just expriment with different kinds of textures and see how they work, how they end up looking, what effects you can get from them, etc. My personal opinion is that you learn more from fiddling and playing that from any other source. ;) bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
