Subject: That is weird...:O
Mesh_Magick opened this issue on Aug 26, 2003 ยท 5 posts
Mesh_Magick posted Tue, 26 August 2003 at 7:29 AM
I went to export something from poser 4 but the 3ds,obj ect export filters are no longer in the list. I have poser 5 also loaded on my computer, Did poser 5 pull away the export filters from poser 4? If so how can I get the filters back without having to reinstall poser 4 all over again?
Mesh_Magick posted Tue, 26 August 2003 at 7:44 AM
I mean the filters are gone, Not there at all.
Mesh_Magick posted Tue, 26 August 2003 at 8:27 AM
Im not sure what caused it but I did solve it by running the poser 4 403 updater at curious labs, it reinstalled the export filters I needed, I was using metacreations early updater, So somehow poser 5 sucked up the filters when I updated with poser 5, Then I moved the runtime folder from curious labs back to metactreations because I had alot of folders and stuff there, Not knowing poser 4's export filters had been sucked dry and absorbed by poser 5. they must work in a batch file way together to explain why that happend. So running the poser 4 updater solved the problem, now if I run poser 5 will the filters still be in poser4 if I leave the folder in curious labs? Or will it get again absorbed into poser 5?
Mesh_Magick posted Tue, 26 August 2003 at 8:29 AM
Do I need to run poser 5 setup again? Will this cause a conflict with poser 5?
pixelwks posted Tue, 26 August 2003 at 9:04 AM
It has happened to me with P4 and Pro Pack several times over the years. In the past I've reinstalled.
