Subject: Free Prop host needed...
jetson61 opened this issue on Aug 28, 2003 ยท 6 posts
jetson61 posted Thu, 28 August 2003 at 6:45 PM
Just some home-made props. Thought some may want. Need a host. let me know. Some carved directly from Mike's face/ Others were carved from the Batman mask that used to be somewhere here or at Animotions. Haven't been able to located the original.
shadowcat posted Thu, 28 August 2003 at 9:40 PM
If you carved them directly from mike's face make sure you have encoded them. Mike's mesh is copyrighted. How big is the file?
jetson61 posted Thu, 28 August 2003 at 9:45 PM
Small ...the set Zipped is less than 300 k
sturkwurk posted Fri, 29 August 2003 at 6:17 PM
Very cool, but shadowcat is exactly correct, you'll have to encode the files. Doug
I came, I rendered, I'm still broke.
jetson61 posted Fri, 29 August 2003 at 9:12 PM
what do ya meen encode?
shadowcat posted Fri, 29 August 2003 at 11:32 PM
You need to get a utility called Mover (in freestuff) this program will "lock" the .obj of your props. The key to unlock the props is the original item that you made the props from. If this is not done you cannot legally share the masks.
