Subject: Millenium Toddler?
gordons opened this issue on Aug 29, 2003 ยท 7 posts
gordons posted Fri, 29 August 2003 at 1:17 PM
I've been trying to make a toddler-size character (P4 pro pack) but haven't had much luck. The Millenium girl doesn't resize well at all - changing the figure height creates a lot of very weird joints and tapered sections. I can't just resize the whole body because toddlers have different ratios for arm and leg length. Any ideas or links would be appreciated.
Dizzie posted Fri, 29 August 2003 at 1:45 PM
have you tried using the Mil baby from DAZ?
SWAMP posted Fri, 29 August 2003 at 3:55 PM
If you are going to be doing alot of work with this character,then as Dizzie said,get the Mil baby. If you'r not going to use it that much,use the PreSchooler not the Preteen. See the size different between PS and PT. I just shorted the arm,forearm,leg,and shine by 90%..shorted the chest(y axis)a little,and stuck the tummy out(z&X axis).Perhapes make the head a little bigger,but I just did this real quick to give you an idea. SWAMP(time for my nap nap)
Elsina posted Sat, 30 August 2003 at 1:29 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=480034
I did this image a few days ago using the milennium baby.
My gallery @ Renderosity
elgyfu posted Sat, 30 August 2003 at 9:20 AM
Penny in quite cute if you have Poser 5
gordons posted Sat, 30 August 2003 at 10:29 AM
I will try the baby, thanks for the tips. Unfortunately the preschool milkid doesn't match a toddler's body shape at all.
SWAMP posted Sat, 30 August 2003 at 5:41 PM
Well I just was showing what you could do with the PS,if you were in a pinch(didn't want to invest in a new figuer). I have the Mill Baby,and can say I really like it alot(wrinkles and all). Check out a tex by ByteMeOK for the little one in the MP...really looks good. Have Fun,SWAMP
