Forum: Vue
Subject: Windows XP - Vue d'esprit and OPENGL
rodluc2001 opened this issue on Aug 30, 2003 ยท 8 posts
rodluc2001 posted Sat, 30 August 2003 at 3:19 PM
Hi all, i've a problem with my new PC, after the reinstallation of vue if i use OpeGl acceleration ' can't work, because i can't see nothing but noise... if i uncheck the opengl i can use the wireframe view... can someone help me ??
Veritas777 posted Sat, 30 August 2003 at 4:26 PM
That IS your most likely option- using the wireframe view. I have a state-of-the-art OpenGL card from Radeon, and every OpenGL app works great accept Vue. So I don't use it- that will likely be what your choice is too. Fortunately, I don't mind using wireframe as I'm very used to it from previous versions of Vue, so it doesn't bother me. (I'm on Windows 2000 Pro)
sittingblue posted Sat, 30 August 2003 at 4:46 PM
Attached Link: http://www.guru3d.com/
You could try using an older video driver (for nVidia cards). I use Detonator 23.11 without any problems. Guru of 3d offers the driver as a free download.
Charles
lingrif posted Sat, 30 August 2003 at 6:07 PM
There are times when open GL really is helpful - placing things on elevated areas of landscapes, for example. So I turn it on, do what I need to do, then turn it back off again. I have an NVIDIA GeForce MX 440. If I leave Open GL on, movement starts to get jerky moving things in the scene.
www.lingriffin.com
haegerst posted Sat, 30 August 2003 at 6:28 PM
Ive tried different drivers for my matrox card, but after experimenting a bit I always ended up in turning it off... That seems the more stable and in some cases even faster option...
Vue content creator
www.renderarmy.com
rds posted Sat, 30 August 2003 at 9:33 PM
I use: Operating system: Windows XP Pro CPU (type & freq.): P4 2.4 mghz RAM & HD space: 1.00 GB of Ram 80gig HD space Video board: NVIDIA GeForce4 Ti 4200 Desktop resolution: 1024x768 Color depth: 32 bits (millions of colors) Open GL works just fine for me. Regards, shoop
gebe posted Sat, 30 August 2003 at 11:24 PM
OpenGL works fine for me too, but mostly I turn it off, because Vue is much faster without it:-) Guitta
rodluc2001 posted Sun, 31 August 2003 at 4:52 AM
10x a lot...
