DarkElegance opened this issue on Sep 02, 2003 ยท 4 posts
DarkElegance posted Tue, 02 September 2003 at 10:49 PM
ok I have an idea...O.o but NO idea how to make it. what I need to do is to ...er...glue two figures together. but cant seem to do it so that when I bring it back into the scene they stay stuck together. I went to the grouping tool...but I just dont think it worked. and now they are siting together and I keep geting cross talk whenI bring in the final figure and it messes everything up... How do I glue...or freeze to human forms to make one unit??????
https://www.darkelegance.co.uk/
mateo_sancarlos posted Wed, 03 September 2003 at 12:08 AM
Set parent of figure 2 to figure 1.
DarkElegance posted Wed, 03 September 2003 at 12:14 AM
I did that and whenI brought in the other figure it cross talked I think and POOF unglueand actually as I think of it....I want to glue to the two together and if possible remove all the un needed morphs and all good stuff make it like one obj
seeklight posted Wed, 03 September 2003 at 3:39 AM
Hello what i do is this.. First modle the props as an individual piece, so if you have 2 pieces,export them from your modeling prog as obj. Then run them in uv mapper and save the maps and the obj, then import each piece to poser position them were you want them and them export as one obj,then bring them back intop poser and there you have one obj with both groups and materials set up so all you do is paint on the maps and apply them to the prop hoipe this helps regards seeklight
