Subject: POSER5 TO BRYCE5 TO POSER5
treeabear opened this issue on Sep 05, 2003 ยท 6 posts
treeabear posted Fri, 05 September 2003 at 11:40 AM
I just got poser5. I have used poser4 some and i use bryce5, how can i get the obj's that i have made into poser4 or 5 and how can i get dynamic hair to transfer to bryce.
gammaRascal posted Fri, 05 September 2003 at 11:59 AM
you can export poser body parts or figures as obj (after youve morphed them or whatever) or you can directly import the figures obj mesh from its instal directory. dynamic hair will export as well if it included in the grouping but it wont look that good. try it out and post a pic of your results.
treeabear posted Fri, 05 September 2003 at 2:11 PM
here is a test render in bryce
gammaRascal posted Fri, 05 September 2003 at 2:26 PM
looks good to me! i dont know about the eyeslashes thought. i just tried exporting some hair... it doesnt seem to want to export as an obj. back when i tried it, i was working in .3ds format and it exported. it just didnt look good at all. you might want to skip over to the bryce forum and see if anyone can help or has any ideas on laticing some hair or you should consider using a polygon wig. as for your eyes, since the poser eyes are several bits together, its only the outer ball...um, labeled eyeball i think, that you can either delete all together or make it trans. (after you ungroup in bryce)
Spit posted Fri, 05 September 2003 at 3:54 PM
Attached Link: Grouper
Bryce objects made from primitives are not exportable. So you can't get them into Poser. And Poser 5 dynamic hair only exports the guide hairs, so you can't get the hair into Bryce. For a great utility that really helps when exporting objects from Poser to Bryce, try Grouper.
slinger posted Fri, 05 September 2003 at 8:07 PM
There's a pretty comprehensive tut on transferring from Poser to Bryce on my site Digital Twist in the Tips section if anyone is having problems.
The liver is evil - It must be punished.
