Subject: Poser5 and transmapped hair problem
jerr3d opened this issue on Sep 06, 2003 ยท 8 posts
jerr3d posted Sat, 06 September 2003 at 2:01 AM
This is a pz3 which worked fine in PPP.
When I open the same file in P5, Firefly renders it like this!
ghack! (that's geekspeek for help!)
nyguy posted Sat, 06 September 2003 at 2:12 AM
I have seen this before. How I fixed it is remove the map save the file again then reopen it and add the map. It worked for me. Also you might want to check to see if the map is tiled somehow in the mat room.
Poserverse The New Home for NYGUY's Freebies
PabloS posted Sat, 06 September 2003 at 2:28 AM
I think some of Koz's hair did this. He's posted a solution on his webpage; however, just plug the map into the displacement node and set to .0001 If that's the problem, it should work.
Dagon posted Sat, 06 September 2003 at 3:30 AM
Attached Link: http://www.keindesign.de/stefan/poser/firefaq.html
some additional tips here (link)
DistantWorlds posted Sat, 06 September 2003 at 6:50 AM
Dragon, thanks for the great tips now my P5 renders faster! Maybe you know how I use P4 reflection maps in P5, too? ;)
Jim Burton posted Sat, 06 September 2003 at 9:44 AM
Anybody know a fix for the problem with transmapped hair in P5 reflections? Where strands don't show, and you get sort of a white halo?
Little_Dragon posted Sat, 06 September 2003 at 6:28 PM
I thought they fixed that with one of the early service releases. Is it coming out the same colour as the background?
Jim Burton posted Sat, 06 September 2003 at 7:26 PM
I think I have the latesest SR, SR3 I think, no it seems to mostly be white. I'll have to see if I can find a render that shows it (the problem) better. I've seen one other post here on it, so it isn't just me. ;-)
