Subject: Bad media file?
Xenobug opened this issue on Sep 06, 2003 ยท 7 posts
Xenobug posted Sat, 06 September 2003 at 1:13 PM
Hi, I'm hoping someone here can help me with a strange error I'm getting when trying to import my figure into Bryce. I recently purchased the Malifica clothing set for V3 and when I export my posed figure as an .OBJ file it won't import into Bryce. I get an error that says "a file error has occoured (i/o bad media). I can import the figure and the clothes separately but not together, and the clothes won't import if they're in certain poses. It's very strange. Has anyone else heard of this problem?
Spit posted Sat, 06 September 2003 at 1:32 PM
Attached Link: Grouper
Yes, this is a bug in Poser's exporter. Doesn't happen all the time and I don't think anyone has nailed exactly when it will happen. Used to happen to me only on props, but it happened on a figure the other day. Anyway, there is a fix or two. The problem is Poser puts in some invalid stuff that you can fix with a text editor...Where you see #IND subsitute a 0 (zero). I usually just run the object through Grouper which fixes the problem automatically.
dan whiteside posted Sat, 06 September 2003 at 1:36 PM
Attached Link: http://www.uvmapper.com/
If you don't have it download UVMapper Classic (free). Load the .OBJ into UVM and turn right around and save it under a new name with the Export defaults. You can also use the free Grouper app which does the same thing: http://www.castironflamingo.com/tutorial/grouper/index.html HTH; Dan
chohole posted Sun, 07 September 2003 at 1:49 AM
Could also be something as simple as Bryce not liking a texture name. Bryce doesn't like names to be too long. Try renaming your textures.
The greatest part of wisdom is learning to develop  the ineffable genius of extracting the "neither here nor there" out of any situation...."
Spit posted Sun, 07 September 2003 at 3:26 AM
Bryce imports long texture names okay. It just doesn't like saving 'em out again, like in your project. :(
slinger posted Sun, 07 September 2003 at 5:42 PM
There's a decent tut on my site about fixing this, under "Tips" http://www.psalmons.co.uk
The liver is evil - It must be punished.
Xenobug posted Mon, 08 September 2003 at 9:53 AM
You guys are awesome! I ran it through Grouper and it imports fine now. Whew! I didn't know about Grouper. What a nice program. Sure beats running through the list of objects trying to find the one you want! Thanks for all your help! :-)
