Forum: MarketPlace Showcase
Subject: Animatable Volumetric Fire,Smoke and Water in Poser,WeirdJuice3D's Metaforms
foleypro opened this issue on Sep 07, 2003 ยท 37 posts
foleypro posted Sun, 07 September 2003 at 9:37 PM
Attached Link: http://www.renderosity.com/artistdownload.ez?fileid=6448&key=277727
Well folks I am here once again to show folks the Awesome Product called "MetaForms"...This Modeling Module for Poser is just the start for the stunning Possibilities of modeling within Poser now,We will be able to build anything possible,Animate Volumetric Fire,Water,Smoke,Blood,Magical effects mist/Blood/gore rolling across the ground or smoke trailing from an animated Torchfire or campfire all this is possible and only limited by your computer...This animated Gif is just a small one that the makers showed us Betatesters and I couldnt help but let you guys in on this stunning animation and the possibilities are endless..
Excerpts from the tutorial follows:
In this simulation, Metaballs rise from a single point into a broad column. At the base of the column, where the Metaballs have their highest intensity, and greatest degree of overlap, the high combined field strength makes more of the bright yellow and orange inner layers visible. At the top of the column as the Metaballs expand and seperate, the combine field strength is lessened and the outer (black) layers of the surface dominate, giving a smoky impression.The simulation is built from 45 Metaballs, all members of a single surface,The surface mapping mode was set to Field Spherical to take advantage of the rotation of the Metaballs and the tiling was set to a factor of two.
U and V Map Perturbation was also added to create additional swirling. The Pertubation Phase of the surface prop has been keyframed to create a smooth change throughout the course of the animation.
Now this is just the start and I will let you all see the progress as I do the Torchfire and smoke...
PS...Click on the link to see the fire....
foleypro posted Sun, 07 September 2003 at 9:38 PM
Ok I know its a small gif but like i said it is just supposed to be a teaser....Sorry As Always B3D
foleypro posted Sun, 07 September 2003 at 9:42 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12413&Form.ShowMessage=1398632
For those who missed the first installment of "MetaForms" just click on the link and you can see several Screen captures of Metaforms in action...
sixus1 posted Mon, 08 September 2003 at 12:37 AM
WOW! That is quite impressive. Got any higher res renders? I bet this stuff in conjunction with P5 shaders could be really powerful.
foleypro posted Mon, 08 September 2003 at 6:35 AM
Thanks Sixus1. I am going to be doing the tutorial thru the week into the weekend and will post Screen shots as I go along I am going to be doing TorchFire,And I will render at 640x480 at least,they just wanted to show us what they were talking about...
SothArtist posted Mon, 08 September 2003 at 6:47 AM
wow.. Now this looks really stunning. Huge poosibilities! And if people like Sixus are impressed it's a great sign :)
MaterialForge posted Mon, 08 September 2003 at 6:49 AM
Oh, sweet. Will explosions be possible with this? That'd be too cool... Still, I'll buy it! Animated smoke is just what I need for some renders.
ynsaen posted Mon, 08 September 2003 at 8:46 AM
Still curious to know more about the tool itself. While the image is impressive, what of greater importance (imho) is the usability and learning curve associated witht he product. The interest is there, but I needs ta know more, chile. Share a bit with me...
kayjay97 posted Mon, 08 September 2003 at 11:19 AM
I am with Elle. Could you share a wee bit more info?
In a world filled with causes for worry and anxiety...
we need the peace of God standing guard over our hearts and minds.
Jerry McCant
WeirdJuice posted Mon, 08 September 2003 at 2:19 PM
Hi Everyone
We thought it was time you got some feedback from the company regarding the MetaForm Product.
First off, thank you to Brian for your continual support and for showcasing some of Metaforms abilities.
My name is Cheryl and I deal with all the non technical aspects of the company, including general correspondence. We hope to be able to provide some more specific information regarding the final feature list, release date, price and purchase information of MetaForm in the very near future but in the meantime we would like to answer some of the questions which have been asked on the Forum.
Our designer has given the following answer to your technical queries:
The product will be packaged with a Users' Manual, including tutorials and examples to get started. Additional tutorials and materials will also be packaged and available as online resources addressing more specific effects and techniques.
The philosophy has been to create an open-ended product which will allow users to find new ways of achieving specific effects and new things to do with the product. We expect people will have a lot of fun experimenting with the possibilities.
Most of the functionality is available through simple button clicks, and standard Poser interfaces such as prop manipulation, parameter dials and timeline editing. We have avoided re-inventing the wheel wherever possible.
Explosion effects will certainly be achievable using the same techniques as the fire simulation demonstrated by Brian.
The product will be available for Poser 4 ProPack and Poser 5 users. Much of the built in material functionality uses advanced texture mapping which can be used by both Poser versions, but Poser 5 shaders can also be applied and it is expected that P5's volumetric materials and MetaForm's multi-layer surfaces and advanced UV mapping techniques will provide a powerful combination.
On a more personal note, I recently tested the Metaform product. Having never used Poser or any other modelling products in the past, I was pleasantly surprised to find that I could use and manipulate the Product to model a simple object with great ease. The only time I had to ask for help was when I was trying to navigate the poser tools. Therefore, I would definately say that the product is very user friendly - even for a beginner like me.
I will be following the Forum threads and will answer as many of your queries as I can however I will have to pass more technical queries over to the technical team. In the meantime though I will ask for your continued patience as we are currently working on the final functionality of the product.
Thanks
Cheryl
odeathoflife posted Mon, 08 September 2003 at 3:56 PM
I looked at the other thread, ..., but have a question, is this a plug in for poser? By that I mean is this modelling made in poser or made in Metaform abd brought into poser?...what is the process?
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
WeirdJuice posted Mon, 08 September 2003 at 5:03 PM
Hi The product is a plug-in which is launched from and is dependant on Poser. One clarification is that the first release will be Windows only. As a new, small company we do not have the resources to develop the Product for the Mac platform. However we fully intend to address the possibility of porting the product in the medium term. Cheryl
odeathoflife posted Mon, 08 September 2003 at 5:12 PM
and so we have a price range yet or it that TBD?
♠Ω Poser eZine Ω♠
♠Ω My Homepage Ω♠
sixus1 posted Mon, 08 September 2003 at 5:13 PM
Is there a website where we can all see more about this?
WeirdJuice posted Mon, 08 September 2003 at 5:21 PM
The price will be announced once we have a definate release date and feature list. We are still adding functionality to the product so it is impossible to say at the moment. Sixus, we will publicly launch the website at around the same time. As Brian mentioned earlier, we do not want to distract our developers and technical team with emails at the moment. Any questions regarding the product can be fielded through this forum so feel free to ask and we will do our best to answer them. It is late on this side of the pond and I need my beauty sleep so will reply to other posts tomorrow. Goodnight all. Cheryl
foleypro posted Mon, 08 September 2003 at 8:55 PM
Like I said folks better bookmark this thread because things are just gettin started and the fun is ready to begin...I agree with Cheryl I am learning Poser5 too and These are so easy to use that folks will be building stuff in ten minutes after reading the manual...I will upload some more Pics very soon...
c1rcle posted Tue, 09 September 2003 at 2:21 AM
Traveler posted Tue, 09 September 2003 at 6:20 AM
Excellent! I can't wait for this to be released. Very exciting!
foleypro posted Tue, 09 September 2003 at 6:46 AM
HeHeHaaaaa.....Folks this is going to help all of us in so many ways...Stay tuned They are adding more functions into the product and I will be getting the updates and Playing I will definitely be uploading some more Modeling Pictures this weekend and hopefully a liitle animated gif 640x480 of the Torchfire...As for interacting with Poser figures/Props I have been informed that it can be done...BUT we will see due to the time involved with de-bugging...As Always B3D
saxon posted Tue, 09 September 2003 at 11:15 AM
odeathoflife posted Tue, 09 September 2003 at 1:13 PM
Hey if Judy can hold a flaming torch while walking through a cavern and have it animatable with smoke billowing I will be in heaven
♠Ω Poser eZine Ω♠
♠Ω My Homepage Ω♠
kayjay97 posted Tue, 09 September 2003 at 1:15 PM
Jerry McCant
foleypro posted Tue, 09 September 2003 at 6:59 PM
Odeathoflife that is the very first animation I was planning on doing but I am not going to be using Judy(Uggghhhhllllllyyyyyy)and I just dont have the time to Morph a new Judy so I will just use what I have...And with me getting Natural pose I am going to see how Metaforms imports as an animation into Bryce?Hahahahaha I hope it works because then we will start to really have fun...And before you say it "But Bryce already has Metaballs"That is great but I was thinking more along the line of the Models you could build and export out with you poser animations...Some just say there is no hope for me,And some times I agree...As Always B3D
hauksdottir posted Tue, 09 September 2003 at 8:28 PM
Watching with fascinated eyes... just like a cat...
TrekkieGrrrl posted Wed, 10 September 2003 at 10:57 AM
Bookmarking!
judith posted Wed, 10 September 2003 at 11:12 AM
bookmarking! Awesome stuff!
What we do in life, echoes in eternity.
E-mail | Renderosity Homepage | Renderosity Store | RDNA Store
sixus1 posted Wed, 10 September 2003 at 11:48 AM
Someone should test this plug in's compatability with other bridge plugins such as Reiss Studio.
foleypro posted Wed, 10 September 2003 at 8:30 PM
sixus1 I am sure it will be sometime down the road,I will ask and see what they say...Keep checking back....Thanks
_Audrey posted Wed, 10 September 2003 at 10:01 PM
Odeathoflife: Dodgers dungeon lighting kit at DAZ can do all of that except the smoke. He says he will keep that in mind for future dlk stuff and exspansions.
akin_ posted Wed, 01 October 2003 at 7:40 AM
Well..... It seems a wonderful product ! Anynews nowadays ???? :) A'kin
nornaddict posted Wed, 01 October 2003 at 7:46 AM
ditto to what akin_ asked, how's metaform shaping up? pun intended ;)
foleypro posted Wed, 01 October 2003 at 8:01 PM
Akin and Nornaddict,I am working on the animation and the guys are implementing features to give on the fly EFFECTS like fluids and fire and smoke and they are going to be doing Mat poses and Poses,From what I understand this all will be a one click deal for the effects and of course you will be able to build mostly anything...I am having a new machine built so I am down to using my roommates computer when I can so I have not been able to play as much as I want but I am supposed to have the new computer this weekend... Ratteler...Yes it works superb in Poser4PP and Poser5...
TrekkieGrrrl posted Thu, 02 October 2003 at 12:56 AM
Oooh Ratteler, that looks GOOOOOOD :o)
akin_ posted Thu, 02 October 2003 at 3:47 AM
More and more interesting indeed ! =)
nornaddict posted Thu, 02 October 2003 at 4:20 AM
I can't wait for this :) can we get it soon?
foleypro posted Thu, 02 October 2003 at 6:39 AM
Yes Ratteler it will be possible to build a model like this and more then likely better and you will be able to animate any or all parts and with Posers Setup room making all sorts of animateble Characters are going to be possible,Animals,Aliens,Globs,Running water,Flames,Smoke,Partical effects,Name it and it might very well be possible............ You see we are not just playing with Metaballs,We have "METAFORMS" boxes,planes,cones,filaments and more to come,so designing any type of figure is going to be possible BTW excellent job on the modeling....
foleypro posted Thu, 02 October 2003 at 8:00 PM
Will let ya know...
