Subject: Looking for Rose with Falling Pedals
krbtv opened this issue on Jul 23, 2000 ยท 7 posts
krbtv posted Sun, 23 July 2000 at 10:10 PM
Does anyone know where I can get a rose where I can make the pedals fall to the ground. I guess what is need is a rose poseable prop and a pedal prop so I can make a pedal (rose leaf) invisible then let the rose leaf fall to the floor. I don't know if I'm making any sense.
shadownet posted Sun, 23 July 2000 at 11:34 PM
There was a rose prop posted in free stuff, it is in .sit format so I never d/l as I can not open. I would think you could spawn a prop (stem and pedals in sections) in Poser, and assemble and use it. By this I mean you have the stock with the individual pedals parented to it. You could then make the pedals rotate and fall off one at a time. Should not be that difficult to do. If I had the rose prop I could give it a try for you. But you can probably do this yourself with no problem using the grouping tool in Poser. Rob
LoboUK posted Mon, 24 July 2000 at 3:33 AM
shadownet's suggestion is exactly how I'd suggest doing it. You can get a PC application that opens SIT files - its a free d/load from Aladdin Systems called Aladdin Expander Paul
shadownet posted Mon, 24 July 2000 at 11:46 AM
Paul, Thanks for the tip on the d/l program for sit files. On my way to fetch it now. Krbtv, You should be able to do this okay. But, I will d/l the rose prop and tinker around with it when I have time. The idea of falling rose pedals sounds cool. If I come up with something that works I let you know. BTW - didn't I see a blooming flower prop posted somewhere? Rob
DbS posted Mon, 24 July 2000 at 3:05 PM
Good! It's still there!!! http://www.renderosity.com/download.ez?uploadid=291 You have to download the entire figure (NOT the slightest waste of disc-space, imho). They're actually leaves in the thumbnail, but a simple colour change will make realistic petals :) ~Dave
shadownet posted Mon, 24 July 2000 at 4:41 PM
Poser world - in the model section, page 15 (I think) has a wonderful growing, blooming, flower prop. Look for the Amazing Miracle-Grow Tulip by Bloodsong A little reworking and this could be made to look like a rose. Rob
shadownet posted Mon, 24 July 2000 at 9:22 PM
Krbtv, Is this what you wanted? rose4u.jpg It's nothing fancy but it will do what you described. I basically took Robin Woods Rosebud from free stuff and Bloodsongs Tullip from Poser World and spawned the parts I needed and made this into a cr2 figure (kind of sorta - the Ik is a bit off, and a few other things, as this was done hastily). If you still needed let me know and I will zip it up and send it to you. (This was done in Windows so if you are a Mac user, I don't know if it will work right - should but I am not certain.) Rob
