eqplayer opened this issue on Jul 24, 2000 ยท 4 posts
eqplayer posted Mon, 24 July 2000 at 1:12 PM
bergerac posted Mon, 24 July 2000 at 4:12 PM
I still work with Poser3, so I don't know if this will be of any use, but here are some suggestions: 1. I'm not too sure about this one, but at most you should only have to hit "drop to Floor" at every key frame. 2. There's a slider called "Play Range" at the bottom of the animation palette that you can use for this. 3. In Poser3 the ground plain is more or less like a prop. You make it visible by ticking it on the guides menu, and you can move it (Y-tran/X-tran/Z-tran) or scale it in your first frame, delete all susequent keyframes for that element and it should stay where you put it. Hope it helps. Berge
pack posted Mon, 24 July 2000 at 8:49 PM
1)No universal drop to floor. Read bulk change above. Other work around is to resample keyframes (to make less work) then click next keyframe arrow with one hand, Ctrl D with the other & step thru all the keys one by one. I've been bugging Larry W about adding this feature. 2)In AnimPalette drag arounf all beginning keys & delete. Then drag arounf end keys & copy & paste to the begining. I think also can svae pose over range of frames as well. 3)Uncheck Display/Guides/Ground Plane
Wizzard posted Tue, 25 July 2000 at 2:22 AM
egg, a quickie.... pull open the heirarchy window, click on the GROUND, close window... the ground will stay until after the render.. neat ne? 8 ) Wizzard
