rreynolds opened this issue on Sep 12, 2003 ยท 7 posts
rreynolds posted Fri, 12 September 2003 at 3:55 PM
What does "!M3 IPB Prep" do? It's a file that comes with the base Michael 3 character and is in the Pose library under "!DAZ's Michael 3". All I get when I click it is a Poser 5 error message stating, "The file being read is not a valid Poser file". I cannot quite figure out what it does based on the icon. I've got to figure it's there for a reason. Victoria 3 did not come with this pose, so I'm curious what it is.
dirk5027 posted Fri, 12 September 2003 at 3:57 PM
hope you get an answer, i'm curious too
Puntomaus posted Fri, 12 September 2003 at 3:59 PM
Yep, V3 has it too, it was released later with the InjectionPoseBuilder. You will need this pose when you use this lil proggie to create INJ/REM files.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
DraX posted Fri, 12 September 2003 at 4:02 PM
the IPB Prep pose strips all morph deltas and material settings so that when the figure is saved as a cr2 file it will load faster in InjectionPoseBuilder for building INJ poses.
dvitola posted Fri, 12 September 2003 at 6:13 PM
Is it for P4 or just P5?
Photopium posted Fri, 12 September 2003 at 7:05 PM
The same error message appears in P4. Something is wrong with the file, presumably...bracket problems somewhere perhaps. Meanwhile, no module exists for INjection Pose builder to work with M3. You can still use it, but you have to do a lot of hand editing. -WTB
DraX posted Fri, 12 September 2003 at 10:34 PM
William, IPB HAS been updated for Michael 3, as the brokers already have it. I believe DAZ was putting some finishing touches on the updater before making it live.
