Subject: Dumb Stupid Problem
DSQRD opened this issue on Jul 25, 2000 ยท 7 posts
DSQRD posted Tue, 25 July 2000 at 11:27 AM
I have the dumbest problem that I can not solve no how. I openned the animation palette from the Windows toolbar. While I was repositioning it I moved the title block off the poser work area. Now I can't find a handle on the animation pallete to allowing repositioning of the pallete. I've tried exiting poser and then coming back in. When I turn the animation pallete back on the pallete is displayed with the header block off the poser work area. Any Ideas??
DbS posted Tue, 25 July 2000 at 11:40 AM
Quickest way would be to reinstall, I think. I've had to do it a couple of times for equally "Dumb" screwups I've made. ~Dave
visque posted Tue, 25 July 2000 at 11:50 AM
Perhaps if you set to factory default under preferences.
PhilC posted Tue, 25 July 2000 at 12:17 PM
If you are feeling brave open PoserRuntimeprefsPoser.ini in a text editor I have the following lines in mine:- ANIM_PALETTE_LOC 189 384 ANIM_PALETTE_ON 0 ANIM_PALETTE_SIZE 800 353 Back up the Poser.ini, Poser.exe and Poser.rsr files just incase, and ensure that Poser is closed before you alter the file. Legal disclamers..... dont do it!!! on your own head be it!!!! I told you nuffin!!! :) but that's what I would do if it had hapened to me. Good luck PhilC
Nance posted Tue, 25 July 2000 at 1:33 PM
The "Factory Defaut" in Preferences would be the easiest & safest.
DSQRD posted Tue, 25 July 2000 at 3:04 PM
Thank you all. The correct answer is EDIT Preferences factory default Once again thank you
Nance posted Tue, 25 July 2000 at 4:26 PM
...and when you get it re-fixed the way you want it, saving the GUI in Preferences, as well as to one of your UI Memory Dots will bail you out should it happen again.
