kuroyume0161 opened this issue on Sep 14, 2003 ยท 9 posts
kuroyume0161 posted Sun, 14 September 2003 at 1:08 PM
off.
-- Bjarne
Stroustrup
kuroyume0161 posted Sun, 14 September 2003 at 1:09 PM
off.
-- Bjarne
Stroustrup
Lawndart posted Sun, 14 September 2003 at 1:44 PM
Use a very small bevel between the top and side (thickness) when creating the object in the 2nd example. This will fix smoothing. Poser has no smoothing groups so it is trying to smooth the object between a 90% angle. That is what gives you these funky shadowed areas. This is assuming a lot of things since you don't give that much info. I don't know what is up with the first example. I hope this helps, Joe www.3-AXIS.com
kuroyume0161 posted Sun, 14 September 2003 at 1:57 PM
off.
-- Bjarne
Stroustrup
kuroyume0161 posted Sun, 14 September 2003 at 2:08 PM
Also, smoothing is turned off for all of the parts. There is no need for smoothing on non-organic surfaces like these (and it also avoids the infamous P5 "bubble" renders). I've tried importing the OBJ file with and without welding, with and without normals. Seems to me, by the thousand renders done of this model in Poser for testing, that Poser lighting works polygon-by-polygon instead of taking an entire surface (polygon-polygon angular relationship) into account. Smoothing does this for organics, but not in this case. Help, please!
off.
-- Bjarne
Stroustrup
TrekkieGrrrl posted Sun, 14 September 2003 at 3:13 PM
Try splitting vertices in UVMapper. Usually when my props look like that a "split vertices" helps it. No matter if I have beveled it or not :o)
kuroyume0161 posted Sun, 14 September 2003 at 3:25 PM
Thanks, ernyoka1. I will give that a try and reply on the results - please be good! ;)
off.
-- Bjarne
Stroustrup
kuroyume0161 posted Sun, 14 September 2003 at 4:08 PM
ernyoka1, are you a man or woman? Because I'm gonna marry ya! ;0) That fixed about four or five linguering problems - especially in rendering! Leave it to UVMapper to solve all of the world's problems. Thank you very much!
off.
-- Bjarne
Stroustrup
TrekkieGrrrl posted Sun, 14 September 2003 at 5:00 PM
Hehe I'm a woman, and I am not sure bigamy is allowed? ;o) Just glad it worked. It usually does the trick but it DOES make the files a little larger :o)
