Subject: Anim8or help needed!
DigitalDreamsDS opened this issue on Sep 15, 2003 ยท 2 posts
DigitalDreamsDS posted Mon, 15 September 2003 at 10:33 PM
Ok, i used this link to help me make flared sleeves for the P4 long sleeve blouse.. or whatever its called. http://3dtoday.com/Tutorials/2000/sept/posermorph/default.asp But, when I porph it in Anim8or and try to load it in Poser it says "Target geometry has wron number of vertices." What am I doing wrong. Tricia (pbellows)
igohigh posted Mon, 15 September 2003 at 10:52 PM
Perhaps you Exported the 'entire' blouse and not Just the sleeves (1 right and 1 left)? The P4 long sleeve blouse is like a charater and each part (ie. left shoulder, right shoulder, neck, chest, etc) have to be treated separately. Or, did you Add any vertices to it? use the new knife tool in ver8.5? As you can NOT add any verticals if you wish it to be a morph or you will get this error. The only two possibilities I can think of: 1) you exported too much and need to do the parts individualy. 2) somehow you added verticles to the morph.
