Subject: Correct me if i'm wrong...
cmjackson opened this issue on Sep 17, 2003 ยท 7 posts
cmjackson posted Wed, 17 September 2003 at 10:41 AM
I thought Poser 4 needed RSR files (but dosn't require PNG's) in order for the thumbnail to show up in the libary, and i thought Pro Pack needed PNG's (but dosn't need RSR files) for the thumbnails to show. Have i got this right?
Spanki posted Wed, 17 September 2003 at 10:45 AM
You're close. Poser 4 (PC version anyway) requires .rsr files. Poser Pro Pack and Poser 5 both use .png files instead. If there are no .png files, Pro Pack and Poser 5 create them from any existing .rsr files (which you could then delete). So as long as you have .rsr files, you're all set for any version of (PC) Poser. If you're on a Mac, you should be using Mac Converter.
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
cmjackson posted Wed, 17 September 2003 at 10:51 AM
thanx chum
LaurieA posted Wed, 17 September 2003 at 11:03 AM
Thanks Spanki. I didn't know that ;o) I only have Poser 4 Laurie
Lyrra posted Wed, 17 September 2003 at 12:01 PM
cmjackson just so you know in some cultures being called 'chum' is an insult. It's a kind of fish and what's used for sharkbait. I'm fairly sure that's not what you meant :)
Spit posted Wed, 17 September 2003 at 8:44 PM
I always thought the alternate definition of 'chum' was pal or friend.
Little_Dragon posted Wed, 17 September 2003 at 11:09 PM
"Fellow" was once an insulting or condescending term, also, although that usage seems to have been forgotten by now.
