paques opened this issue on Sep 18, 2003 ยท 3 posts
paques posted Thu, 18 September 2003 at 12:02 PM
Need help with Bryce 5.1 on xp1700+computer with XP home edition and 512kb mem onboard. Since a few days suddenly a problem. Description: I make a simple animation of a revolving sphere with texture A . This goes Okay.. Next i want the same animation with another texture .when rendering , I can see it rendering the same first picture over and over again.No movement anymore . First I suspected a corrupt direct draw file , so i updated to the latest directx 9 , but still the same problem. Anyboddy knows waht i am doing wrong? Brdgs ren
pauljs75 posted Thu, 18 September 2003 at 3:00 PM
How about this? You might have your material mapped to world space. If that's the case, then whatever texture is on your sphere is not going to rotate with it (all frames will look the same.) You'll have to change the setting on the material mapping mode to object space. If you don't know where the control is located, I'm sure one of the friendly Brycers here will do a screen grab for you. If that's not the case, check the animation scroller. You may only have one frame set for the entire range.
paques posted Thu, 18 September 2003 at 3:09 PM
Thanx , I will look at that!
