Subject: Poser 5 question
Foxseelady opened this issue on Sep 19, 2003 ยท 3 posts
Foxseelady posted Fri, 19 September 2003 at 1:01 PM
Hi all I'm still considering p5, not sure I need all the extra stuff but kind of thinking I want it lol. What I'm curious about is the poser 4 stuff I have accumulated. How does poser 5 use this? I know it can be used, but do I need to copy alllll those files into p5 (sounds like to much space) because I'd still want to use 4 or would p5 somehow read from p4? Thanks
stewer posted Fri, 19 September 2003 at 1:13 PM
No, you don't have to copy anything. You can simply add your existing runtime to your new P5 installation.
pdxjims posted Fri, 19 September 2003 at 1:55 PM
P5 has much better handling of the library structure. Adding the P4 library doesn't involve moving anything, just identifying the new library to P5. However, injection posing required the Delta files to be in the main runtime. So you do have to copy the one !Daz library directory and all the files over to the main P5 directory if you have V3 or M3. Not tough at all.
