Amadan opened this issue on Sep 20, 2003 ยท 7 posts
Amadan posted Sat, 20 September 2003 at 8:07 PM
Using Poser 5. I have two figures in the same scene, both wearing dynamic clothing. Following HMann's excellent free tutorial on dynamic clothing, I have discovered that while I can clothify both clothing items, they can only be set to collide against the same set of objects/figures. Changing the figure against which one item of clothing will collide also sets the other clothing item to collide against the same figure. When I render, one item of clothing will drape correctly, but the other one goes sailing off to try to "collide" with the other figure.
Frame 1: Zeroed poses
Frame 5: Final pose
Is there any way to put two figures with dynamically draped clothing in the same scene?
Thanks,
-David
Little_Dragon posted Sat, 20 September 2003 at 8:31 PM
Hmmm. Perhaps it would work better if you created a separate simulation for each clothing item? Then you could have different collision targets for each clothing item, although it would take longer to set up as you'd have to calculate each simulation separately.
PhilC posted Sat, 20 September 2003 at 8:34 PM
Have you tried creating a separate simulation for each piece of clothing? A scene may include more than one simulation.
Little_Dragon posted Sat, 20 September 2003 at 9:06 PM
jerr3d posted Sun, 21 September 2003 at 12:53 AM
Your animation looks great Little Dragon! Does someone have the link for the above mentioned HMann's tutorial? thanks!
Little_Dragon posted Sun, 21 September 2003 at 5:18 AM
It's available in .pdf format at Poserfashion.
jerr3d posted Sun, 21 September 2003 at 8:25 AM
Thanks Little Dragon
