Subject: INJ in P5 causes lockup, reinstall P5 question
pack opened this issue on Sep 23, 2003 ยท 8 posts
pack posted Tue, 23 September 2003 at 1:04 AM
I think I deleted the wrong file in the P5 root folder. I accidentaly unzipped stuff there without paths turned on. Now P5 locks up every time I use an INJ pose. Anyone know what I did. If I uninstall Poser5, does it wipe out my Runtime folders? regards, Pack
Kelderek posted Tue, 23 September 2003 at 1:16 AM
You can temporarily rename and move your old runtime before reinstalling Poser 5. Then replace the new runtime with the old one. I would think that is the safest route to take.
Jaager posted Tue, 23 September 2003 at 1:19 AM
You did not mees up Poser 5, you are just sending it on a snipe hunt. It is not locked up, it is looking for !DAZ If it is not in Runtimelibraries it needs to be. The other *.cr2 and *.pz2 just go into their proper libraries.
pack posted Tue, 23 September 2003 at 6:03 PM
I see in the Libraries!Daz folder subfolders called Victoria 3BodyChanVis. Is that where you mean?. If so- where specifically? I don't see how poser can look there since its not in the usual locations- Character-Pose-Faces- etc. I bought a V3 character- the instructions & unzip paths all specify the Pose folder. Please advise, Pack
pack posted Tue, 23 September 2003 at 6:33 PM
In case you're wondering I bought all the V3 body & & head & Male morph packs, & installed them- 338 files in the !DazV3bodyChanVis folder . Sorry for being so dense, I have read the info at the Daz website-
Jaager posted Tue, 23 September 2003 at 10:07 PM
"338 files in the !DazV3bodyChanVis folder " You mean that you messed up the structure of the files inside !DAZ? All of the files are inside the same folder? Oh bad! Poser 5 ain't hurt, but V3 is not going to work. Reinstall V3 with paths. You can install to an empty folder and find all of the misplaced folders in Poser Runtime that you installed incorrectly and delete them. They may even sort together by date. then drag the new files over, or delete them and install V3 again directly to P5 Runtime I don't even want to think about what it looks like if all of those *.pz2 files are all mixed together. Some are intended to be in the Pose library and some in !DAZ - inside the correct folder there. The actual *.pz2 files that have the readScript paths in them may be in any folder in Pose library you wish. In P5 you can even nest them - should nest them = all INJ in one main folder and all REM in another. The files in !DAZ - the files that the paths in the readScript files are calling must be where the readScript path expects to find them. Otherwise Poser may have a long term absence seizure while it pretends to look for the files. To touch base on the basics, these files are all simple text files. You can view them in a text editor.
pack posted Sat, 27 September 2003 at 12:18 AM
Thanks Jaeg. I have PP & P5 both installed. The INJ's work for PP, but not P5. When I try reinstalling V3, I can't install her in the P5 (Curious Labs/Poser 5 folder, it can't find the orig Victoria. I suspect a bogus V3 install, as do you. Thanks, Pack
Jaager posted Sat, 27 September 2003 at 3:32 AM
Duplicate the folderand copy the V1 geometry to it in P5 Geometries and the installer will work. But actually, all you need to do is right button (copy) the whole !DAZ folder to the same place in P5. The other files can stay in P4.
