raptordude opened this issue on Sep 23, 2003 ยท 7 posts
raptordude posted Tue, 23 September 2003 at 7:57 PM
randym77 posted Tue, 23 September 2003 at 8:33 PM
Change your document display style to "texture shaded." (Ctrl+9) Keep in mind that showing the textures may slow down your computer. That's why the default is not to show them.
Kelderek posted Tue, 23 September 2003 at 10:57 PM
Also note that "Texture Shaded" only gives you a crude impression of how the textures look. To get a true picture of the textured model, including light settings etc, you need to render. There is no way around that.
raptordude posted Wed, 24 September 2003 at 12:55 AM
Thanks for the come-back but........ I do have the display set for texture shaded. If I turn off all lights then it looks much better.... this just looks over lighted or washed out some how. I have not had this trouble with any other model.... just this one. Like I said in the first post....When I started with this one the Highlight size was set to 100.0000.....dont know why.....I set them all down to 1.00000 and that helped somewhat. Thanks for the help raptordude
Dash posted Wed, 24 September 2003 at 3:14 AM
What i can see on your screenshot is that the ambient color is set to white, this makes the model glow or light up try setting it to black. If the ambience is part of the texture effects you want then you gotta live with it :)
randym77 posted Wed, 24 September 2003 at 5:37 AM
Yes, try making the ambient color black. Also, your highlight size is pretty big. Try 0.1 instead of 1.0.
raptordude posted Wed, 24 September 2003 at 10:52 AM
Thank you.....Thank you....Dash and randym77 that fixed it. Once again a simple fix for my "major" problem hehehehe Thanks again for the help raptordude
