satfj opened this issue on Sep 28, 2003 ยท 7 posts
satfj posted Sun, 28 September 2003 at 12:15 AM
I'm trying to create a targa file with alpha channels in it. For some reason photoshop 7 is not saving the transparency. Any suggestions? Any tutorials.... Thanks
Hoofdcommissaris posted Sun, 28 September 2003 at 2:35 PM
DhamonGrimwulf posted Fri, 10 October 2003 at 9:00 AM
first of all i wanna say i'm a big noob, just bought photoshop7.0. how 2 make a special piece of a pic transparent? i sat infront of my pc the whole night an finally made it, but i don't know how and i think there are easier ways to do so.
retrocity posted Fri, 10 October 2003 at 9:31 PM
Hi DhamonGrimwulf, welcome to the forum,
One of the best way to make a part of your picture transparent is to use a mask. This method is "non-destructive" (meaning NO pixel are injured in the process ;)) and gives you the flexibility to change your mind.
If you do a search on the forum for the topic "transparency" you should find a few helpful threads.
If you have a specific example you want us to help you with, please, by all means, post it to a thread and we'll take a look.
hope to see you around,
retrocity
DhamonGrimwulf posted Sun, 12 October 2003 at 8:15 AM
i think, the most problems i solved myself... it takes a little time to become a photoshop allstar ;-) thx for all
karosnikov posted Sun, 12 October 2003 at 9:51 PM
well if your image is flatened I don't think you can make a a part of it trans-parent.. it all boils down to layers. the eraser or selection mask will help you - Duplicate the BackGround layer - and trash the original.. your new "BackGround copy" can now be slightly erased to your desired requirements just grab an old image you like and use either a mask just make a selecion and when you are happy with it go to the Chanel and view the mask chan only and perhaps adjust the - when you find out wich way is the right way you can basicly Coose the level of transparency in the particular area you masked... exit the mask and DELETE it go a head n make a new layer and fill it white ( or something ) put it under the "layer copy to see the effect. or use an eraser @ 40% ( for example ) and -> try not go over a part of the image twice with the eraser <-
Hoofdcommissaris posted Mon, 13 October 2003 at 3:08 AM
Double clicking on the background layer is an easy alternative for duplicating and trashing. It will be named 'Layer 0' by default if you click 'okay'.
