Lothaekor opened this issue on Oct 01, 2003 ยท 7 posts
Lothaekor posted Wed, 01 October 2003 at 10:23 AM
Hello, It's been a while since I've had a chance to play around with Poser 4, and hence haven't been around the Renderosity forums for a while, but I seem to have reached a sticking point. Currently, I'm modeling "accessories" in sPatch, exporting to DXF, importing into Poser, exporting to OBJ, using UVMapper to generate a texture map for the OBJ file, and finally importing the OBJ back in and using it. My problem arises when I've got a few different OBJ files attached to the same character. When the figure is exported, all the OBJ files are grouped together into one group. One group means one texture, and as a result, the texture is fine on the object it's meant for, but it messes up all of the others. Is there any way to force Poser 4 to export each imported OBJ file as its own object in a single OBJ file (character and props) without actually going through and exporting each object seperately? (The OBJs require resizing and repositioning otherwise, which is a pain to do in Bryce 5) Any help is much appreciated. Lothaekor
