Mivan opened this issue on Oct 03, 2003 ยท 4 posts
Mivan posted Fri, 03 October 2003 at 8:07 AM
I would like to place a bmp on a 2d pic object as a background for a scene. How do I stop it from tiling? Can it be backlit like a photo transparency? I would also like to know if Corel has been sold or did they just sell the rights to bryce? Thanks Mivan
TheBryster posted Fri, 03 October 2003 at 11:01 AM
Yes, it can be backlit, as for the rest...........
Claymor posted Fri, 03 October 2003 at 11:57 AM
Yes, you can apply a bump map to a 2d plane. TO stop it from tiling..if it is a pic you should be able to set the scale to either 0 or 1 and the mapping to object cubic or object front and get it to work. If you want it to be photo-transparent you have to fiddle with the transparency setting.
shadowdragonlord posted Fri, 03 October 2003 at 7:02 PM
If you are using a "backdrop", Mivan, you don't need to use an infinite plane. Use a 2D Square object instead. There will be no tiling unless you TELL it to tile. The image will stretch to match the dimensions of the square itself. Corel has nothing more to do with Bryce, they are ashes now, Mivan. Bryce will live or die, just like the rest of us...
