Sun, Dec 1, 4:17 AM CST
Renderosity Forums / Bryce
Welcome to the Bryce Forum
Forum Moderators: TheBryster
Bryce F.A.Q (Last Updated: 2024 Nov 26 4:28 pm)
[Gallery]     [Tutorials]
THE PLACE FOR ALL THINGS BRYCE - GOT A PROBLEM? YOU'VE COME TO THE RIGHT PLACE
Subject: Realistic Trees
Gog ( ) posted Fri, 03 October 2003 at 10:28 AM ยท edited Sat, 23 November 2024 at 12:39 AM
Been trying to increase the realism on trees, in particular playing with leaf textures. I put in some background and a simple sky to give the image a bit more 'feel' The trees are (left to right):- 1)Default Apple Tree 2)Procedural Texture used, with World Space rather then Object Space set. 3) Hand painted image texture used 4) as 3) but using World SPace rather then Parametric mapped. Which do you guys think is most realistic? (I'm not interested in trunks/ shape just the leaf texture bit...) I kind of like 4 because I can make dark/light or even browned areas on the tree.
TheBryster ( ) posted Fri, 03 October 2003 at 11:03 AM
Forum Moderator
#2 looks good to me........
GROINGRINDER ( ) posted Fri, 03 October 2003 at 12:16 PM
I can't tell.
GROINGRINDER ( ) posted Fri, 03 October 2003 at 12:17 PM
All the leaves look overly large.
amethyss ( ) posted Fri, 03 October 2003 at 12:40 PM
Not sure if this will help, but when I do trees now I duplicate the one,then twist it slightly and move a tad behind.Then I texture the trees with my digital photos using the image edit for trunk and leaves.Also the material edit must also be set with the same image.Darken it in the DTE.Use parametric.on leaves. Not much of a tutorialist but maybe you get the drift.
Painting: The art of protecting flat surfaces from the weather and exposing them to the critic_____website
amethyss ( ) posted Fri, 03 October 2003 at 12:41 PM
Oh ....I also use different images for each tree.
mboncher ( ) posted Fri, 03 October 2003 at 3:11 PM
I use the proceedural textures, but I tweek them a bit (getting rid of transparency and ambience, muting the colors and so forth. I've had very good luck with tweeked base bryce textures. What I've noticed the most problems with the tree generator is in the trunk and branch creation. It's very hard to get realistic trees just using basic settings, and God forbid you try to do a conifer!
shadowdragonlord ( ) posted Fri, 03 October 2003 at 6:57 PM
I've made perfect conifers once, for a scene of a hunting cabin, I'll try to dig it up and post a screenshot.... Gog, my stupid monitor here at work is too dark, when I get home I'll try and give you a fair analysis of your textures...
eelnek ( ) posted Fri, 03 October 2003 at 8:49 PM
Recently I have made a few trees and plants with real leaves and flowers snipped off and scanned in a flat bed scanner- several looked quite realistic
Erlik ( ) posted Sat, 04 October 2003 at 1:32 AM
Two and four are the best looking. Because they are not symmetrical.
-- erlik
